Curved VS Straight Loaders: PHOTOS
   / Curved VS Straight Loaders: PHOTOS #51
Bob..... Thanks for taking the time to put this together. I think people try to get tied up to much in the technical minutia, when the only constant that matters is the operator. The machines are what they are as manufactured and trying to tie in seat heights, length of hoods etc., is not applicable in my opinion. This is why whenever someone posts the question "which tractor do I buy" the most common response.. try them all and get the one you are most comfortable with, along with "reputable dealer". I apprciate the fact that you used 2 different tractors of "comparable" size. To me... the more you can see and can apply depth perception, the better you are and if curved loader arms help accomplish this, than I see it as a benefit. All this and I don't even have a tractor with a loader /forums/images/graemlins/crazy.gif
   / Curved VS Straight Loaders: PHOTOS #52
I'm gonna jump in here again with another thought about curved loader arms. I think they are easier to manufacture and this may be a strong reason they appear on new lines of compact tractors. Kubota has building compacts much longer than New Holland, John Deere, or Kioti. Their tooling and factory processes would have to be changed to accomodate such a radical change in geometry. I think the production lines of New Holland and Kioti are probably using new tools and techniques for bending the tubing that makes up the arms and they are producing a loader that reflects that ability to manufacture in a different way.
Maybe it's all bogus theory, but I think we always should put the economics of change into the equation. If Kubota feels their market share is lacking because of not having a feature like the curved arms, I bet they will respond. Has anyone heard of a whole new production series of tractors from Kubota? With the surge in compact sales, everyone is looking for something new and "spiffy" to market. /forums/images/graemlins/cool.gif
   / Curved VS Straight Loaders: PHOTOS #53
I'm not sure I can agree with that - I imagine that curved arms would take an investment in the right kind of manufacturing equipment, while the straight arm design can be built with fairly rudimentary processes. Once you’ve got the equipment then it might be a bit quicker and easier, but while it might save a couple of welds in the middle it still involves all of the same processes as the straight arms do, it just adds the bending step.
Jim & Chris, I suspect the arms are not bent at all.
On the inside of the arms is a seam that might be some sort of a weld??? The seam runs the length of the tube. I would suspect that the tube, which looks like a square wall tube that is bent, is really folded thick sheet steel that is then welded? The seam is very neat, neater than most welds I've seen, so considering I sell candy to kids, and considering it doesn't take a lot of brain power to do that, I might be totally wrong.
   / Curved VS Straight Loaders: PHOTOS #55
My son-in-law took my tractor back over to Okeechobee to do some hurricane cleanup, so I can't run out and check, but I think I always assumed that the arms on my 12LA were forged. I never "thunked" them to see if they were hollow or solid, but they just seemed to have a cast or forged look to them. and I don't think that cast would be strong enough.
   / Curved VS Straight Loaders: PHOTOS #56
</font><font color="blue" class="small">( I suspect the arms are not bent at all. )</font>
</font><font color="blue" class="small">( ...is really folded thick sheet steel that is then welded? The seam is very neat, neater than most welds I've seen,.... )</font>
Bob, after running Wroughtn_Harv's bending machine and seeing how easy something like this could be done (just on a bigger scale), I'm going to disagree. I'm also going to point out that you even stated the best reason I can think of that the arms are not welded. I've looked at my arms and I don't see the bead you spoke of, but I saw lots of welds on the ends and in the middle where the lift and tilt cylinders attach. None of those welds are as neat as the weld you speak of. Why would NH make that weld near perfect on the arms, grind it down to bodyshop quality, and then have normal "sloppy" welds on everything attached to it? I believe the arms are an extruded square tube that is bent on some type of rolling jig that puts it in the perfect shape before the ends are installed. That bead you see may be from the roller and the fact that the metal on the inside of the bend has to be compressed.
OkeeDon, I think if you'll just tap on your loader arms you'll hear they sound hollow. Just imagine how much heavier they would be if they were solid. /forums/images/graemlins/crazy.gif
   / Curved VS Straight Loaders: PHOTOS #57
I have to say that you put some effert and thought into it and it shows, nice job. But. When I bought my tc30 I looked at the NH with the curved front and as far as seeing and using the bucket, there was no differance. On mt TC30 (squared front) I can see the cutting edge of the bucket perfect. I think the seat position and the physical size of the operater makes a differance. If your on the short side, then your going to be standing up on the seat. If your average height like me 6' then you'll probally have no problem. For the differance in money for the machines I wouldn't base my decission soley on the bucket, there are other factors to consider.
   / Curved VS Straight Loaders: PHOTOS #58
I just took a good look at mine and I have to agree with Jim as they really do look like they were bent/formed and then the ends were attached.
   / Curved VS Straight Loaders: PHOTOS #59
Mad wrote:
</font><font color="blue" class="small">( If not then the viewing angle to the front will be different which will influence the distance viewed forward thus skewing the results. )</font>
One thing that shows this clearly is the horizon line in the four pictures side by side that shoppingtractors posted - ideally it would be the same - but the camera is pointing up more in the Kubota photos than it is in the NH photos (it's fairly close in two of the photos but still favors the NH slightly.) This will affect the view - making the NH seem as though it provides more visibility - and the Kubota less - that's just a fact, optical and geometric.
Bob writes:
</font><font color="blue" class="small">( With the operator being used as the control factor, then the frame of view remains realisticly valid. )</font>
But only if the operator is looking out on the same geometric plane. Try tipping your chin up an inch while taking the NH photos and see what happens.
In my normal day job as an CG (computer graphics) artist and 3D animator one of the things I often have to do is match actual live action footage shot with a camera and then composite in 3D elements. In order to maintain illusion and suspend the disbelief of the viewer it is necessary that the perspective of 3D computer generated imagery exactly match the live footage. This means that number of things (field of view, camera angles, lighting, etc.) have to match between both the actual camera footage, and the 3D elements which I create, which are eventually then composited together. If one fails to make the match, it is readily apparent that something is 'wrong' - most people will sense this even if they can't quite put their finger on exactly what it is.
One way to handle this in this test would have been to put two objects a couple hundred feet out (one in front of both tractors) and then point the camera at them (putting each object in the exact center of the frame.) This would have resulted in almost exactly the same perspective, but would probably be hard to get an exact match handholding a camera.
Having said all that, it is fairly clear to me that the sloped hood/curved arms probably do provide better forward visibility close in, even though the evidence provided isn't exact or perfect, it's probably close enough.
BTW, thanks Bob for taking the time and effort - it's a pretty good illustration.
<font color="green"> even though the evidence provided isn't exact or perfect, it's probably close enough.
</font>
Well I tried to shoot from the same relative position and make them as good as possible. My goal was to present as unbiased view as is possible.
While you have the trained eyes and can make a strong case that my pictures are not perfect, I do appreciate the fact that you indicated that they are close enough to show that the evidence I presented is valid.
Based on the basic validity of the images, I think now it is up to the individual user to decide for themselves how much they could benefit from the sloped hood curved arm set up. After using both on many occasions, I believe most people underestimate how much benefit they would receive, but while I believe that, I wouldn't trade in a tractor to get a curved arm machine. But it buying new, I would definately factor the ease of use and the added productivity into the decision process because if I can work faster, then I can get more work done in less time . . . and that is the reason I got a tractor in the first place.
WERK-BRAY 23" PIN ON BUCKET (A52706)
WERK-BRAY 23" PIN...
2015 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2015 INTERNATIONAL...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
Towable Diesel Generator (A59228)
Towable Diesel...
20FT X 30FT ALL STEEL CARPORT (A58214)
20FT X 30FT ALL...
