Cushion for FEL? (Front End Loader)
   / Cushion for FEL? (Front End Loader) #11
I belive with some research you can find aftermarket ride control systems for equipment. The only thing is, every implement I have run with ride control, requires it to be disabled when loaded.
   / Cushion for FEL? (Front End Loader) #12
when the tractor begins hip hopping from rear tires to front tires off the ground, and when you look behind you, you see "pot holes" from tires squashing ever few feet into the ground...
plumb it inline for the FEL arm cylinders, would be interesting to see.
be nice if there was an "addon package" you could toss on the physical valves themselves. to reduce need for an actual accumulator. and just use tractors open center hydraulics.
be nice, if there was an "addon package" that allowed accumulator to slide inside the frame work of the FEL arms, or FEL arm supports. to reduce space taken up. by accumulators.
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
JOHN DEERE 350D OFF ROAD DUMP (A51242)
JOHN DEERE 350D...
2022 Club Car Tempo Golf Cart (A48082)
2022 Club Car...
2005 MACK CHN613 WINCH TRUCK (INOPERABLE) (A50854)
2005 MACK CHN613...
2022 Mower King SSVR72 72in Hydraulic Vibratory Roller Skid Steer Attachment (A49346)
2022 Mower King...
2025 12v Diesel Pump (A48081)
2025 12v Diesel...
