Cutting a PTO Shaft
   / Cutting a PTO Shaft #1
40_acre_mule
South Mississippi
Kubota L4701
I need to cut a pto shaft to length for my generator.
My question is...
What is the minimum amount of overlap needed for safety and reliablility?
   / Cutting a PTO Shaft #2
Minimum is 6" as I recall, I would leave as much as possible, that way later down the road you could use it with a different tractor.
Aaron Z
   / Cutting a PTO Shaft #4
It would be better if you bought a new one for a few reasons:
1. you will have a shaft attached to the generator at all times.
2. elimination of the wrong time, wrong place, I have it someplace
else on another machine syndrome and its dark and I have no heat.
3. you want at least 50 percent of the internal male portion within
the external tube because of the shaft speed and torque.
leonz
   / Cutting a PTO Shaft #5
Great video here. Whats that a camera on the left fender? Maybe to view whats happening behind?
Thanks y'all. I knew the folks here would come through.
I have a shaft for each implement except this generator.
The genny is mounted on a home made 3ph bracket.
The setup resulted in an odd length for the drive shaft.
I tried to buy a shaft that was the proper length, but had no joy.
Anyway, thanks again.
   / Cutting a PTO Shaft #8
the over lap on a pto shaft is about 6 to 12 inches and if you need to be closer to your tractor like you said it is on the 3 point hitch cut it 2 inches shorter then your longs throw of your arms either down or up if it bindes cut it a little shorter, measure from the end of each shaft with it mounted,, down postion ,middle postion and up and see which one will be better,that way the shaft will not fall apart on you when you transport it from place to place it will run best straight off the pto.a little jack shaft will work just make sure you are lined up good and straight on the rear pto shaft with the jenny end.
2015 Toro Workman MD Utility Cart (A53421)
2015 Toro Workman...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A56129)
2007 FREIGHTLINER...
2017 Ford Explorer SUV (A53424)
2017 Ford Explorer...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
UNUSED HURRICANE STAND ON SKID STEER (A52706)
UNUSED HURRICANE...
