Cutting edge for b21
   / Cutting edge for b21 #11
I believe if you check into the cutting edge it is just like the B26 and is double edged so when one side wears you can just remove and turn it over. That is one reason the cost is so high for installation as the holes have to be perfect so it will fit in both directions. :) The Gotcha Man
Gotcha, I did try that and my dealer told me that the two buckets were different in size. I thought that they were the same but I might be wrong.:confused:
   / Cutting edge for b21 #13
mopar3500, I'm sorry as I may have confused you. I'm not sure of the size of the bucket for the 21. I do know the heavy duty bucket for the B26 is 60" and the medium duty (standard is 66"). What I was mainly referring to was the bolt on cutting edge. It is beveled on both sides so that it can be turned around when one side wears you can bolt on the other side. As said in another thread if you plan on installing a tooth bar you will have to remove the cutter bar as the mounting bolts get in the way of the pre-manufactured bars. :)
The Gotcha Man
I have no use for the tooth bar but I appreciate the measurements on the buckets . Thanks
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
2022 K-Z Sportsmen 260BHSE 28ft T/A Travel Trailer (A51694)
2022 K-Z Sportsmen...
2014 Chevrolet Cruze Sedan (A51694)
2014 Chevrolet...
ECHO SRM-225 GAS WEED EATER (A51248)
ECHO SRM-225 GAS...
2010 International 7300 Bucket Truck, VIN # 1HTWBAAN0AJ212190 (A51573)
2010 International...
(1) 24ft Free Standing Panel (A51573)
(1) 24ft Free...
