Cutting Fluid Film
   / Cutting Fluid Film #1
JJZ 109
Veteran Member
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
I've got a gallon can of Fluid Film that I mostly use to paint the underside of 2 riding mower decks after pressure washing every fall. I had some FF in a pump sprayer and cut it with denatured alcohol, as that was the only thing I saw hanging around the garage at the time. It worked somewhat, but could have been much better. Should I have just watered the FF down more with the alcohol or is there a better cutting agent for sprayer use?
   / Cutting Fluid Film #2
Fluid film is petroleum based. Use a petroleum based thinner, if you have to cut it. Paint thinner, kerosene, mineral spirits, etc.
Thanks for the reply. I just visited their FAQ page (which would have been a smart thing to do in the beginning!). Here's what they have to say:
"The first recommendation is to thoroughly mix the product. FLUID FILM is thixotropic, and will get heavier upon sitting. Achieving room temperature with the product will help as well. If a thinner version is wanted, start by mixing a small amount of vegetable oil to the product until the desired consistency is reached. It is not recommended that FLUID FILM be used in a pump type sprayer even after thinning. Airless paint spraying equipment is what is recommended for proper application, applied at approximately 2000 PSI as a minimum."
For my current use, right out of the bucket with a paint brush works just fine for mower deck undersides. I was curious in case I ever decided to spray the underside of the truck.
   / Cutting Fluid Film #7
Thixotropic. That's a new one for me. "Will Get Heavier Upon Sitting". I know a lot of folks like that!
   / Cutting Fluid Film #10
Nope. Fluid Film is made from lanolin. Which comes from sheep. Looks like the OP has already found the thinning instructions.
2025 New/Unused LandHonor 13,000lb Electric Winch (A51573)
2025 New/Unused...
2016 Toro Pro Force Towable Blower (A50324)
2016 Toro Pro...
23222 (A50323)
23222 (A50323)
JOHN DEERE XUV835M (A53084)
JOHN DEERE XUV835M...
Truck Wheel Fenders (A51692)
Truck Wheel...
