Cutting Fluid Film
   / Cutting Fluid Film #1
JJZ 109
Lake Ontario/St. Lawrence River
Kubota BX2380/LA344 loader/60" MMM, Bobcat S185 skid steer, JD X394 4 wheel steer mower
I've got a gallon can of Fluid Film that I mostly use to paint the underside of 2 riding mower decks after pressure washing every fall. I had some FF in a pump sprayer and cut it with denatured alcohol, as that was the only thing I saw hanging around the garage at the time. It worked somewhat, but could have been much better. Should I have just watered the FF down more with the alcohol or is there a better cutting agent for sprayer use?
   / Cutting Fluid Film #2
Fluid film is petroleum based. Use a petroleum based thinner, if you have to cut it. Paint thinner, kerosene, mineral spirits, etc.
Thanks for the reply. I just visited their FAQ page (which would have been a smart thing to do in the beginning!). Here's what they have to say:
"The first recommendation is to thoroughly mix the product. FLUID FILM is thixotropic, and will get heavier upon sitting. Achieving room temperature with the product will help as well. If a thinner version is wanted, start by mixing a small amount of vegetable oil to the product until the desired consistency is reached. It is not recommended that FLUID FILM be used in a pump type sprayer even after thinning. Airless paint spraying equipment is what is recommended for proper application, applied at approximately 2000 PSI as a minimum."
For my current use, right out of the bucket with a paint brush works just fine for mower deck undersides. I was curious in case I ever decided to spray the underside of the truck.
   / Cutting Fluid Film #7
Thixotropic. That's a new one for me. "Will Get Heavier Upon Sitting". I know a lot of folks like that!
   / Cutting Fluid Film #10
Nope. Fluid Film is made from lanolin. Which comes from sheep. Looks like the OP has already found the thinning instructions.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A54814)
2016 Ford F-550...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
12ft Heavy Duty Aluminum Ramps (A55301)
12ft Heavy Duty...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A53473)
2022 Quick Attach...
CASE INTERNATIONAL 695 TRACTOR (A51406)
CASE INTERNATIONAL...
