Cutting fluid for drilling holes?
   / Cutting fluid for drilling holes? #1
blunosr
Bronze Member
Northern BC, Canada
Kubota MX5000, Ford 5000, Massey Ferguson 1080, Bobcat A300
Hi, I'm re-mounting my FEL and am drilling lots of large holes in 1/2" plate. I have been using motor oil as cutting fluid, but it seems to me that real cutting fluid is some kind of soap?
I've used lots of cutting fluid on lathes, and metal band saws, but I just don't remember what it's really made of. I'm sure someone on here knows...
What do you guys use for cutting fluid?
Thanks,
   / Cutting fluid for drilling holes? #5
Thanks,
I use this stuff
Oatey Dark cutting fluid
Dark Thread Cutting Oil :: Oatey.com
   / Cutting fluid for drilling holes? #7
In a pinch, you can use all sorts of things -- I have regularly grabbed kerosene, alcohol, or WD-40 with good results. I am sure diesel would do as well.
Here's an article with more detail than I could hope to explain:
Cutting fluid - Wikipedia, the free encyclopedia
   / Cutting fluid for drilling holes? #8
Cool tool works well for cutting and tapping it's a bit expensive.
   / Cutting fluid for drilling holes? #9
A machinist told me that you can use water, he said all you are wanting to do is cool the drill bit. Myself I have used WD40, but that gets expensive.
   / Cutting fluid for drilling holes? #10
You want to cool the tool but you also want to lubricate,and keep chips clear to disperse the heat.
2010 Ford Transit Connect Van, VIN # NM0LS6AN8AT009921 (A44391)
2010 Ford Transit...
1 Bridgestone 255/70R 22.5 and 1 Toyo M-872 12R 22.5 Tires (A44391)
1 Bridgestone...
2001 Chevrolet Silverado 1500 4x4 Flatbed Truck (A44571)
2001 Chevrolet...
INOP/NON-RUNNING 2013 Dodge Charger Passenger Car, VIN # 2C3CDXAG1DH721133 (A44391)
INOP/NON-RUNNING...
8Yd Dumpster (A44571)
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A44571)
2015 Ford F-550...
