Cutting fluid for drilling holes?
   / Cutting fluid for drilling holes? #1
blunosr
Northern BC, Canada
Kubota MX5000, Ford 5000, Massey Ferguson 1080, Bobcat A300
Hi, I'm re-mounting my FEL and am drilling lots of large holes in 1/2" plate. I have been using motor oil as cutting fluid, but it seems to me that real cutting fluid is some kind of soap?
I've used lots of cutting fluid on lathes, and metal band saws, but I just don't remember what it's really made of. I'm sure someone on here knows...
What do you guys use for cutting fluid?
Thanks,
   / Cutting fluid for drilling holes? #5
Thanks,
I use this stuff
Oatey Dark cutting fluid
Dark Thread Cutting Oil :: Oatey.com
   / Cutting fluid for drilling holes? #7
In a pinch, you can use all sorts of things -- I have regularly grabbed kerosene, alcohol, or WD-40 with good results. I am sure diesel would do as well.
Here's an article with more detail than I could hope to explain:
Cutting fluid - Wikipedia, the free encyclopedia
   / Cutting fluid for drilling holes? #8
Cool tool works well for cutting and tapping it's a bit expensive.
   / Cutting fluid for drilling holes? #9
A machinist told me that you can use water, he said all you are wanting to do is cool the drill bit. Myself I have used WD40, but that gets expensive.
   / Cutting fluid for drilling holes? #10
You want to cool the tool but you also want to lubricate,and keep chips clear to disperse the heat.
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
Lockwood 845 2-row Mark Air Harvester (A47369)
Lockwood 845 2-row...
2011 Chevrolet Silverado 2500 Ext. Cab Pickup Truck (A45336)
2011 Chevrolet...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A45336)
2018 Generac...
2011 Isuzu NPR-HD Aries Sewer Viewer 16ft Box Truck (A46683)
2011 Isuzu NPR-HD...
2020 INTERNATIONAL LT625 TRI AXLE SLEEPER (A45676)
2020 INTERNATIONAL...
