Cutting Retaining Wall Blocks
   / Cutting Retaining Wall Blocks #1
Johnny_B
Western PA
MF GC2410 TLB w/ 60" MMM
Hello,
I'm getting my tools and supplies lined up for a retaining wall I'm going to be putting in this month (ordered the Unilock Brussels Dimensional blocks today). I have to make 5 or 6 cuts where the blocks adjoin the house, so I'm wondering if I should rent a diamond blade wet saw or just pick up a 14" cut-off saws and a diamond blade from Harbor Freight. Unfortunately the Harbor Freight wet saw can only cut brick up to 3 inches and the bricks I've ordered are 3.9".
HF has two saw options, and I was leaning towards the $99.99 model ITEM 1624-5VGA - Harbor Freight Tools - Quality Tools at the Lowest Prices instead of the $49.99 model.
I've skimmed through the HF tool reviews on the website and have seen some complaints about the metal-cutting blades on this saw, but has anyone ever used this or similar saws (with a masonry blade) to cut retaining wall blocks?
Sorry for the long-winded question...but thanks in advance.
   / Cutting Retaining Wall Blocks #2
You can rent a gas powered cut-off saw with diamond blade from home depot tool rental for about $50.00
   / Cutting Retaining Wall Blocks #3
I just used a masonry saw and cut it free hand. I think I paid between $20-$30 for the day. Good luck on your project.
   / Cutting Retaining Wall Blocks #4
we just put a diamond bladae in a milwaukee metal cutoff saw. Works real good.
gp
   / Cutting Retaining Wall Blocks #5
rental gas saw, the saw rental is cheap, but wait till they hand you the bill for wear on the diamonds:mad: it was more than the saw rental!!!
   / Cutting Retaining Wall Blocks #6
Hello,
I have, don't buy it, It works okay for metal cutting, but as soon as it gets some masonry dust in it, BU-BYE
Rent one, you'll be dollars ahead
   / Cutting Retaining Wall Blocks #7
I used a masonry abrasive cutting blade in an old skilsaw. Cut a groove (3/4" deep?) on all 4 sides around the block, then use a masonry chisel to bust it off where it's been weakened. I was able to split off as small as about 1" slices off the end of a ~10" x 10" block.
   / Cutting Retaining Wall Blocks #8
Yes, an old skilsaw from the pawn shop $15-$20 and an abrasive blade.
If you are trying to notch out block to weave new block in, you can knock out the mortar with a hammer drill.
   / Cutting Retaining Wall Blocks #9
+1 on this, cheap masonry blade can be had for $20. I used my old Sears skilsaw and it still works fine. I Cut a lot of block and flagstone before that blade wore out.
One thing, make sure to get yourself a respirator. That dust is a killer.
Mark
   / Cutting Retaining Wall Blocks #11
I have a small cheap wet tableop saw that I use for tile work and bricks. About $100 bucks for it at Lowes has saved me a lot of time over the past three years.
   / Cutting Retaining Wall Blocks #12
This worked well for me too...:thumbsup:
   / Cutting Retaining Wall Blocks #13
When you all are talking about using a masonry cutting blade in an old skillsaw, I am assumng you mean a metal blade?... what about one of the fiber type masonry blades... I have used them to cut fiber cement columns, and they worked very well... would they also work on block?
   / Cutting Retaining Wall Blocks #15
You can cut block with the plain fiber masonary blades. The worst thing is the dust. Eye protection and a good respirator is probably more important than the saw blade.
KBH Tender (A56438)
KBH Tender (A56438)
Craftsman 42 Inch Riding Mower (A57454)
Craftsman 42 Inch...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
