Cutting Retaining Wall Blocks
/ Cutting Retaining Wall Blocks #1
Johnny_B
Western PA
MF GC2410 TLB w/ 60" MMM
Hello,
I'm getting my tools and supplies lined up for a retaining wall I'm going to be putting in this month (ordered the Unilock Brussels Dimensional blocks today). I have to make 5 or 6 cuts where the blocks adjoin the house, so I'm wondering if I should rent a diamond blade wet saw or just pick up a 14" cut-off saws and a diamond blade from Harbor Freight. Unfortunately the Harbor Freight wet saw can only cut brick up to 3 inches and the bricks I've ordered are 3.9".
HF has two saw options, and I was leaning towards the $99.99 model ITEM 1624-5VGA - Harbor Freight Tools - Quality Tools at the Lowest Prices instead of the $49.99 model.
I've skimmed through the HF tool reviews on the website and have seen some complaints about the metal-cutting blades on this saw, but has anyone ever used this or similar saws (with a masonry blade) to cut retaining wall blocks?
Sorry for the long-winded question...but thanks in advance.
/ Cutting Retaining Wall Blocks #2
You can rent a gas powered cut-off saw with diamond blade from home depot tool rental for about $50.00
/ Cutting Retaining Wall Blocks #3
I just used a masonry saw and cut it free hand. I think I paid between $20-$30 for the day. Good luck on your project.
/ Cutting Retaining Wall Blocks #4
we just put a diamond bladae in a milwaukee metal cutoff saw. Works real good.
gp
/ Cutting Retaining Wall Blocks #5
rental gas saw, the saw rental is cheap, but wait till they hand you the bill for wear on the diamonds:mad: it was more than the saw rental!!!
/ Cutting Retaining Wall Blocks #6
Hello,
I have, don't buy it, It works okay for metal cutting, but as soon as it gets some masonry dust in it, BU-BYE
Rent one, you'll be dollars ahead
/ Cutting Retaining Wall Blocks #7
I used a masonry abrasive cutting blade in an old skilsaw. Cut a groove (3/4" deep?) on all 4 sides around the block, then use a masonry chisel to bust it off where it's been weakened. I was able to split off as small as about 1" slices off the end of a ~10" x 10" block.
/ Cutting Retaining Wall Blocks #8
Yes, an old skilsaw from the pawn shop $15-$20 and an abrasive blade.
If you are trying to notch out block to weave new block in, you can knock out the mortar with a hammer drill.
/ Cutting Retaining Wall Blocks #9
+1 on this, cheap masonry blade can be had for $20. I used my old Sears skilsaw and it still works fine. I Cut a lot of block and flagstone before that blade wore out.
One thing, make sure to get yourself a respirator. That dust is a killer.
Mark
/ Cutting Retaining Wall Blocks #11
I have a small cheap wet tableop saw that I use for tile work and bricks. About $100 bucks for it at Lowes has saved me a lot of time over the past three years.
/ Cutting Retaining Wall Blocks #12
This worked well for me too...:thumbsup:
/ Cutting Retaining Wall Blocks #13
When you all are talking about using a masonry cutting blade in an old skillsaw, I am assumng you mean a metal blade?... what about one of the fiber type masonry blades... I have used them to cut fiber cement columns, and they worked very well... would they also work on block?
/ Cutting Retaining Wall Blocks #15
You can cut block with the plain fiber masonary blades. The worst thing is the dust. Eye protection and a good respirator is probably more important than the saw blade.
New/Unused Quick Attach Pallet Forks (A65583)
New/Unused Quick...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2023 Ford F-350 4x4 Flatbed Truck, VIN # 1FTRF3DM5PEC15665 (A65563)
2023 Ford F-350...
2020 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
2020 International LT625 Sleeper 48" (A62613)
2020 International...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
