Cutting Through A Weld
   / Cutting Through A Weld
Thanks for the link Bird. /forums/images/graemlins/smile.gif Too bad that kit doesn't come with a cut off wheel. /forums/images/graemlins/frown.gif It still looks like a good buy for only $60.
   / Cutting Through A Weld #12
can you reach it by taking the wheels off and pound it out with an air hammer? save cutting it off & welding it back on.
<font color="blue"> can you reach it by taking the wheels off and pound it out with an air hammer?</font>
Mike, I am going to try that when it stops raining. One of the problems I had prying the fender away from the tire (just to get the trailer home) was the only thing I had for leverage was the tire. The aluminum was too thick to muscle it away from the tire, so I stuck a pry bar between the fender and tire. Most of the force I could exert went to compressing the tire, instead of moving the fender. I think once I get the wheel off, a hand sledge might do the trick. The results wont be pretty, but she'll be able to use the trailer until a permanent fix can be arranged.
BTW, how do you attach a cut off wheel to a die grinder?
   / Cutting Through A Weld #14
</font><font color="blue" class="small">( I think once I get the wheel off, a hand sledge might do the trick. The results wont be pretty, but she'll be able to use the trailer until a permanent fix can be arranged )</font>
That's just what I did to the fender on my trailer a few years ago when it got badly bent by all the tread coming off a tire at highway speed. As strong as that fender metal is (mine was steel), it's amazing what a little rubber hitting it can do.
   / Cutting Through A Weld #15
Mike, you'll have better luck reshaping it with a porta-power. It's a hydraulic ram with different extension tubes for different lengths. Commonly used in auto body work where you need a push, not a hit. They're handy for all sorts of things and you can get a four ton model for about $80 at a Harbor Freight type store. Kind of like a come-a-long, in reverse /forums/images/graemlins/smile.gif
   / Cutting Through A Weld #16
Since her track record tells you that you can expect this to happen again..... maybe just try to straighten it until it looks pretty good.
<font color="blue">...maybe just try to straighten it until it looks pretty good. </font>
Amen. /forums/images/graemlins/smile.gif
She and I had a 'conversation' about these accidents. She insisted that each cirumstance was different. I replied that each of them were right hand turns close to a guardrail. Things went down hill from there. /forums/images/graemlins/shocked.gif
   / Cutting Through A Weld #18
I agree with RedRocker, don't use a grinding or cut-off wheel made for steel to use on aluminum. The aluminum will build up on the wheel possibly causing the wheel or disk to fly apart. Use a cut-off disk made for aluminum.
You might take it to a local shop and have them cut it with a plasma-cutter. This would be much quicker and would be a straighter cut.
genelp
   / Cutting Through A Weld #19
I'm not one to attempt to re-invent the wheel, but this sounds like a time when you might want to rethink this fender.
First ask yourself this question. Is that fender worth a happy marriage? (My "fender" was the wife smoking in a new car /forums/images/graemlins/crazy.gif)
Next question. We move on to a remedy. Is that fender part of a/or is it a structural component of the trailer? If not, could it be made from something a little more forgiving? (Plastic? Rubber?) If it's been bent 4 times, there's a good chance #5 isn't too far in to the future.
<font color="blue"> First ask yourself this question. Is that fender worth a happy marriage? (My "fender" was the wife smoking in a new car </font>
Thanks for your concern. /forums/images/graemlins/smile.gif I apologized soon afterwards. /forums/images/graemlins/cool.gif
<font color="blue">If not, could it be made from something a little more forgiving? </font>
The front and back of the fender provide support for small running boards, but that's it. The one good thing about a sturdy fender is that the sound of it being crunched gives the wife plenty of warning that she's too close to something. /forums/images/graemlins/grin.gif
The more that I think about this, the more I think that once I pound out the fender so it's drivable, I'll leave it alone. If we decide to have it fixed, I'll have the local manufacturer replace it.
NEW HOLLAND C362 SKID STEER (A52705)
NEW HOLLAND C362...
2016 KENWORTH T680 SLEEPER TRUCK (A52141)
2016 KENWORTH T680...
(4) GOODYEAR WRANGLER 275/55R20 TIRES (A54757)
(4) GOODYEAR...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51406)
KNOW BEFORE YOU...
FAE UML/SSL 150 VT BL HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
UNUSED LANDHONOR 3.5X2X2M GREENHOUSE (A54757)
UNUSED LANDHONOR...
