Cutting up to 1/4in steel - what do you recommend?
   / Cutting up to 1/4in steel - what do you recommend? #21
   / Cutting up to 1/4in steel - what do you recommend? #22
I use a Milwaukee 8" metal saw, portable band saw and a 4" grinder with a cutoff wheel.
I also have a large band saw Startrite H225 1" saw. I only use a torch for heating and bending.
Plasma cutter would be nice but I don;t have a use for it.
I did buy a twin blade saw for Home Depot. Nice saw I can cut a 2" pipe length ways easy and straight. It make a lot of chips.
Thanks for all the replies gents! I let this run a bit since I was getting great responses but I left out a very key word... cutting 'Curves'. Mostly sheet/plate.
   / Cutting up to 1/4in steel - what do you recommend? #24
I use a jigsaw for that up to about 5/16. Has to be a real good jigsaw and a real good blade, otherwise the bottom of the cut will follow a different line than the top.
   / Cutting up to 1/4in steel - what do you recommend? #25
A jig saw would work, but you must take your time. This is were a plasma cutter works the best or a torch with a #1 tip. Them you have to grind it smooth for a finish.
If I need something that's a one off I see my buddy with a water jet.
Yes I have a good Bosch jig saw but I often get an 'angled' cut due to the blade bending/wandering on the far side. Thus my search for a better set up that won't break the bank. A plasma cutter would be awesome, it's the justification that is the issue. But God knows, I haven't justified most of the tools in my shop :D
   / Cutting up to 1/4in steel - what do you recommend? #27
[snip]
Plasma cutter would be nice but I don;t have a use for it.[snip]
Dangerous talk, Dude, unless you're saying that only to yourself. At least tack on ", right at this moment." :)
   / Cutting up to 1/4in steel - what do you recommend? #28
K0ua - thanks, that's the saw I was looking at, seems like a pretty good value for a small timer like me. :)
It is handy and makes precise angles easily. No sparks and not much noise.
   / Cutting up to 1/4in steel - what do you recommend? #29
Bosch makes a jigsaw blade designed for curved cuts in metal - T218A. It is not a magic bullet but it is less prone to wandering than regular metal cutting blades. Not as costly as a plasma cutter but not as much fun either.
Ha ha... thanks Pat. Might have to hunt that down until I can pull the trigger on a Plasma or Oxy set up.
2012 Audi Q5 AWD SUV (A51694)
2012 Audi Q5 AWD...
2016 Case 821F Articulated Wheel Loader (A51691)
2016 Case 821F...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
JOHN DEERE 333G SKID STEER (A52472)
JOHN DEERE 333G...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
