Cuz-Pat: My Mahindra 7520...I am sick of it!!!
   / Cuz-Pat: My Mahindra 7520...I am sick of it!!! #21
CuzPat62 said:
Then when winter got here I started using it to put out rolls of hay for my cows with the bale spear attached to the tractor. When the cold weather got here is when the smoking problem first appeared.
Cold weather is what normally triggered the KSB failures...so the more info you give us the more and more it sounds like a KSB issue. Those KSB timers can be plugged in incorrectly also, that may be something to look at.
Roughly the KSB adjusts the amount of fuel the engine gets when the tractors engine is at a certain temperature. If the KSB is not working correctly the engine isn't getting the correct amount of fuel it needs therefore the engine feels like it is losing power and it begins to smoke, spit and sputter.
   / Cuz-Pat: My Mahindra 7520...I am sick of it!!! #22
Does the 4110 have one of these KSBs? Also, is the KSB a maintance item; should we change say every 1000 or 2000 hrs etc.?
Cheers
   / Cuz-Pat: My Mahindra 7520...I am sick of it!!! #23
As far as I know the 4110 does not have a KSB, and no this is not a maintenance item. The 25, 00, 30, and 20 Series are the only ones that have them.
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A56438)
2016 KBH...
2004 Ford F-150 4x4 Ext. Cab Pickup Truck (A56858)
2004 Ford F-150...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57454)
New/Unused 14ft...
