IslandManMitch
This is the cylinder that has been used for a top link. It was used cylinder and retrofitted years ago and has worked fine except it has always leaked a little. Getting worse and it is to the point it needs rebuilding. The rod end cover had two 1/4" bolt holding it on which I removed. I put the two bolts back in the cylinder to screw it out. Turns freely but does not screw out or in? How does it come out? Where can I get a rebuild kit? I have looked with no luck? This is the first cylinder I have tried to rebuild and I'm already lost? Thanks for any help, Mitch
