d14 allis 3pt and loader controlled with same valve
   / d14 allis 3pt and loader controlled with same valve #11
Thanks guys! I had a feeling that I need to go that route.
   / d14 allis 3pt and loader controlled with same valve #12
another question, what series is it?
some of the early series used a high pressure/low flow system where the later series were normal pressures like a late model tractor.
IIRC the early system was not compatible with late model implements. and vice versa.
EDIT; this might not apply, I was thinking it was similar to the D17.
   / d14 allis 3pt and loader controlled with same valve #13
Lets back up here and see what you want to do?
What do you have and what do you want to do with any new hydraulics.. You say you have DA cyl's, and if so, then you can have power down and float and regen if you choose the correct valve..
So if you want an independent hyd system for the DA cyl's, then you need a pump, valve, and a reservoir.
Just use what yo have for the 3pt.
Do you have any idea of volume and pressure developed by the pump on your hyd system now?
I am running a 3 GPM pump, 3000 psi off of my fan belt.
You can do the same, and the pump is inexpensive.
http://baileynet.com/index.php?dnfwd=1&page=ProductDetails&line=GPGC&baileyno=250-058
http://www.surpluscenter.com/item.asp?item=9-7401&catname=hydraulic
http://www.surpluscenter.com/item.asp?item=9-4185&catname=hydraulic
Plus some hoses and fittings and filter.
Toro Workman Utility Cart (A51694)
Toro Workman...
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
International 1420 Combine (A50514)
International 1420...
Case IH 7120 Combine (A50514)
Case IH 7120...
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
Texas Built 25' Stand Alone Inline Feeder (A50515)
Texas Built 25'...
