Matt_Jr
Platinum Member
This is kinda like the "should I tow in overdrive" thread. The real reason valves are damaged with leaking exhaust systems- If the exhaust leak is close to the maifold the exhaust valve can be cooled too fast when the engine is shut off. If the valve cools too fast it causes the edge of the valve to warp (same reason brake rotors warp). If the valve is warped it doesn't seal properly. This leak causes burning fuel to go past the valve while it is still at it's highest temperature. This causes the edge of the valve to burn. Thats how you get burned valves. This usually takes a long time to happen (many on/off cycles). If you never shut off the engine it wouldn't be a problem. It's possible no damage has occured to the engine at all on the tractor your looking at but the only way to know for sure is to do a compression test. If compression is low do a leak down test. This will tell you if damage to the valves has occured or not.
Just a note: It's not how hot valves/rotors get that causes them to warp. It's cooling them too fast.
