dead cylinder
   / dead cylinder #1
irl3r
JD 870
I’ve got a JD 790 with a 3tne82a engine with only 539 hours that has a cylinder not working. the tractor started running poorly. so after checking for obvious issues i tried cracking the injector lines one at a time . on cylinder 3 it made no difference in the way the engine ran. i swapped injectors and the problem did not follow the injector . my next step is a compression test. has anyone experienced this issue.
   / dead cylinder #2
Stuck valve?
   / dead cylinder #3
irl3r
Welcome to TBN
When you cracked the lines, did you get fuel at each one?
Do you have the service tech manual?
   / dead cylinder
yes , loosening cylinders 1and2 fuel feed lines the engine nearly cuts off
   / dead cylinder
yes i have manual .
175 psi in #3 cylinder cranking engine over
   / dead cylinder #7
175 PSI seems low for a diesel, did you check the other cylinders for a comparison?
2015 Ford Focus SE Sedan (A50324)
2015 Ford Focus SE...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2016 Ford Explorer...
2006 KOMATSU D41P-6 CRAWLER DOZER (A51222)
2006 KOMATSU...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A51222)
2018 VOLVO VNL...
Woods BW12 Batwing Mower (A50514)
Woods BW12 Batwing...
