Dead tractor
   / Dead tractor #11
Just as a side note.. If you have levers that can lock in a detente, you should install a loop of hose when not in use. By running a deadheaded hydraulic pump you can destroy the pump. It doesn't take long to do that either. Glad the loade is back working again.
   / Dead tractor #12
Hi besmith, I've got a TYM273 and that's a problem I've not had occur in 223 hrs use. Have you checked your sight glass to ensure that the hydraulic oil is full? If so, and no visible hydraulic leaks, my best guess would be one or more of your quick disconnects have gotten loose (as already suggested). Be sure that the 3pt hitch speed control valve beneath the seat is not fully closed, don't know how that might affect anything other than the 3pt but it's another area to check out. Good luck with it. Greg
   / Dead tractor
The lever under the seat was not in the center.Moved it to center and loader and boxblade now work. Still no steering or no movement when engaging fwd or reverse. So still good vas dead.Will keep looking at everything whenever I have time.thanks
   / Dead tractor #14
G'day i do not know your tractor but i would assume that trans and steering is run of one pump and aux hyd of another. I would doubt if there would be any quick connects on your steering as i would assume it would be a priority feed, if you can get to your steering valve easy then look for one of the two hoses that run to the trans and crack it open to see if you have oil flow, do not undo completely and do not get too close as hyd oil under press can do serious damage to your body.
Jon
   / Dead tractor
Jon, thanks will check ,getting down to where it can only be a couple of things.
6' Box Blade (A53316)
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
JOHN DEERE 1700 LOT NUMBER 17 (A53084)
JOHN DEERE 1700...
2010 MITSUBISHI FUSO SINGLE AXLE DUMP TRUCK (A56129)
2010 MITSUBISHI...
CASE 610 Sprayer System 2000 Gallons (A55301)
CASE 610 Sprayer...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
