Death from above..........
   / Death from above.......... #11
Let your pro do it. This is coming from a pro.
   / Death from above.......... #12
That one would give me pause too. I'd definitely look it over real well before putting to a saw. Walk around it a few times to see if you can make out how the stresses are acting on it.
   / Death from above.......... #13
No matter what everyone tells you. There is nothing worse than leaving your wife a widow because of misjudgment. It's just not worth it to gamble like that.
   / Death from above.......... #14
Let a pro do it. Have a beer while watching and enjoying your beautiful view and grounds. A lake in the background and grass and trees to die for. Or not to die for in this case.
   / Death from above.......... #15
After having looked at your pics- leave it alone. It has growth damage near the base of the trunk too.
Don't risk it. This is professional, not amateur advice.
Thanks for all the input gents......I had pretty well made my mind up before I posted that I would have it taken down versus taking it down myself. If I were in my 20,s, 30's,, 40's, or even early to mid 50's, I wouldn't bat an eye at taking it down. While I am good health for my age, one has to know on has limitations and I don't move quite as fast as I used to. Will attempt to get pics, or maybe even a vidio as was suggested, when it comes down.
   / Death from above.......... #18
To quote Clint Eastwood, "A man's gotta know his limitations." The pro is the
way to go. Those trees are called widowmakers for a reason.
When I have trees to cut, if I can't say to myself, "you CAN do this safely",
I call in a pro.
   / Death from above.......... #19
If I was falling it, I would fall it to the side of where it is leaning. With, of course a good hardhat on, and never being under the leaning portion of the tree. But, it could still potentially kick around unexpectedly. Having a chain on it to force it to come down if it gets stuck isn't a bad idea, but probably not required.
One might be able to work above it with a bucket lift, but it is pretty high up, and there is likely tension in both the trunk and top of the tree.
You don't have one of these parked in your garage, do you?
Having your "tree guy" take it down is a very good choice.
   / Death from above.......... #20
Even pros can have trouble. We have had one death and a serious injury around here in the last 18 months.
Pallet of 10 Chains and 5 Binders (A54865)
Pallet of 10...
Ryobi Sliding Compound Miter Saw (A54865)
Ryobi Sliding...
CURTIS 55CFM AIR COMPRESSOR (A54757)
CURTIS 55CFM AIR...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
Toro Cart Run and Drive (A50324)
Toro Cart Run and...
2001 Dodge Ram Pickup Truck (A55852)
2001 Dodge Ram...
