Rustyiron
Super Member
Could you simply replace the motor with single phase 240?
As you measure the motor, I would also keep an eye out for how big a replacement could be. Sometimes minor modifications can give you alternatives. In addition to the common US NEMA motor frame sizes, there is also an international frame series under IEC.I would lose the ability to change speeds which is important in wood turning.
Right now, this has slipped to a very low priority. I've found a place that can rebuild the motor if needed. I do not know what the frame size is and will have to remove the motor to make some measurements to determine that. I suspect it is a custom motor since it is longer and skinnier than all the drawings I've seen of motor frame sizes, but have to measure first.
+1 the only time it's ever worth rewinding a motor is when it's double-digits HP and/or some kind of special purpise-built motor.I did not know that. How do I determine if they're rated for vfd duty?
The motor rebuilder is expensive. A new motor is cheaper.
No disagreeing, but "prematurely" is subjective and may or may not be relevant. On a production machine that gets run at least a full shift every day I would recommend going inverter duty. But for a hobby wood lathe that someone uses (ex) once a month, an ordinary motor powered by VFD will most likely outlast the VFD and probably the owner too. Not worth the extra cost of inverter duty rating.Electric motors must be rated for vfd duty or they will fail prematurely.
The derating advice is golden if you're looking at 3ph input drives. There is a relatively new trend of VFDs specifically rated for single phase input and they do not need to be derated. Some are dual (single or 3ph) rated and they will typically have the ratings for both stamped right on them, so no math required.Show us more of the machine, motor frame size, etc. There are sure to be a lot of options and this may be a chance to get better stuff for less than first imagined.
That said, while SC is our source for 3-Ph motor pulls & take-offs the best deals/inventories come and go. I suggest a longer term vs immediate perspective when shopping there. (oh, the $79 2hp 3-Ph TEFCs I let slip away ..)
btw, the trick to VFDs is being sure whether or not yours is de-rated for 1-Ph input. Cutting it close is when stuff can go South. WIMI, don't buy a 1-2hp VFD for a 2HP motor, buy a 2-3hp if not 3-5hp if you aren't sure. Also don't let anything with critical electrolytic caps (VFDs, CSCR 1-Ph motors, etc) sit for 6-mos without a 1/2 hr or so no load run-in to 'reform' the caps for max life and best performance. (You knew that)
Yep, agreed on all counts. Choke/output reactor is never a bad idea, although I must confess I don't run them (or inverter duty motors) on any of my machines in my shop. I just keep the wiring between VFD and motor as short as possible, and never had an issue. My main lathe is equipped with a 30 y/o blower motor that I pulled out of a dumpster, and I've been running it on a VFD for 8 years now, not a single issue. When it does eventually fail, hopefully it won't take the VFD with it, but if it does, no huge loss as that was also used, close enough to free, and a replacement can be had for less than the cost of taking my dog to the vet."Inverter duty" motors are designed to be run by VFDs. They typically have higher temperature insulation on the motor, and typically higher volume cooling fans to cool the motor at reduced speed. A few even have insulation designed for the high voltage transients that VFDs can produce. (Worth putting in chokes on your VFDs) Some even have armature and stator designs to better tolerate different frequencies. Some have special internal grounding to reduce eddy currents. You will pay a premium for the "inverter" rating, and it is often hard to figure out what you are getting for the price. A premium might be three to ten times the price.
As @strantor said, if you aren't running it at extremes all day long, you will probably never notice. If you are planning on running it all day long, my $0.02 is to buy a reputable brand like Baldor.
All the best,
Peter
