Decided on my first tractor
   / Decided on my first tractor #21
Trying to get info on upper the pressure.
Wish I had someone close to me that knows these Tractors and what to do..., I'm a little nervous !
My previous Tractor, a Yanmar, had two pump
BRMyers,
Seat Belts are a good thing when applied properly BUT when you are in a tipping situation the seat belt gets in the way, so when I am working a hill side or slope, I do not wear the belt... IF the Tractor decides I have over extended the balance point then I want to be able to jump off !
Won't go into RIGHT or WRONG !
Hopefully you will never need to find out, but that ROPS system is there to protect you during that rollover and the seatbelt keeps you in that sweet zone.
   / Decided on my first tractor #22
Nice looking tractor. Here's wishing you many happy hours of service from it!:tractor:
   / Decided on my first tractor #23
Not Strong Enough... why I say that is because I can't drive up my driveway with a full front bucket without stopping and putting the Tractor in Low Range; yes in Low Range it does a decent job !
Lifting, I went by the specs, more than my last Tractor, but to me I feel I have to struggle to get it to pick up the same things, I don't have picture of actual measurements so I can't say absolute, more guessing on the feel.
I was just moving some of Metal shelving with the FEL, strapped it in, backed up, when I went forward and started to roll the bucket inward and the the Tractor slowed, I think the pump isn't large enough to handle the added hydraulic load of two functions at once.
The back hoe, again going by what I remember, the feel is that the Mahindra doesn't dig as well as my older, smaller, Yanmar.
And although not a power thing, I wish this Max28 had a shift on the fly Transmissions; the Mahindra has to be stopped before moving the Hi/Low Lever.
I have checked the Fluid Levels and I have raised the RPM Level while doing projects, so I don't know what else to do but that is a story for another thread.
Ltr
3 range HST? . . . if not that could be your problem. never mind I did look it up 2 range, there is the problem.
2018 RoGator 1100C (A55315)
2018 RoGator 1100C...
2025 Mahindra 6075 4WD Cab Tractor - 71 HP, Loader Ready, Ag Tires (A55315)
2025 Mahindra 6075...
2001 Nissan Pathfinder SE SUV (A55853)
2001 Nissan...
2017 Jeep Grand Cherokee SUV (A55853)
2017 Jeep Grand...
2003 International 9200I (A53317)
2003 International...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
