Decision Made!
   / Decision Made! #11
Re: Decision Made!/tire ballast
Larry -- Water freezes. Also, looks like someone got their weights wrong. (Not sure who, so don't take offense.) If you take 100# of water and dissolve something weighing 30# into it, the solute will weigh more than the water.
Pete in Northern Vermont
   / Decision Made! #12
The only problem Larry, is for those of us in the colder climates. Plain water will freeze and who knows what that would do to the tires/wheels/tractor.
Someone (sorry I forget who) mentioned "rim guard" recently for tire fill. Anyone have the stats on that stuff?
   / Decision Made! #13
Boondox,
WATER FREEZES /w3tcompact/icons/blush.gif !!
Duh! (like I said,... was I MISSING something here?!)
So THAT'S the "point" of using the other mixes. No offense taken,... Thanks, I needed that! /w3tcompact/icons/smile.gif
Re. "someone" having their weights wrong: If you put 30# of cork into 100# of water, the (let's pretend it's a "solute") will certainly weigh more than the water alone, but the unit-of-volume weight will be LESS. So the density of the "something" has to be GREATER THAN the water density, in order to get more for our trouble when we're talking about a "tirefull".
I know you know-this, I'm just having fun with you for catchin' me with that "freezing" oversight /w3tcompact/icons/wink.gif . Musta' slipped back into "Miami"-mode(born and raised.) If I was still there, I'd go with the water-fill. BAD idea for most other places, though, I admit.
I'm still quite-confident , about the water-density figure. Can't be responsible for the other weights, ... didn't post 'em.
This site is a lot of fun,.. just wish "blunders" were'nt so darn public! /w3tcompact/icons/laugh.gif
Larry
   / Decision Made! #14
Rob, see my response to Boondox.
What are you guys, wimps? /w3tcompact/icons/wink.gif
So it might be a little "bumpy" in your tires freeze,... they'll still be HEAVY!!
Re. "Rimguard": I have the specs (but not handy),... I called and spoke with the mfr., and then went with the (impressive, I thought) info to my local "Big"-tire dealer.
They were not overly impressed, because the stuff is full-volume, and would have to be "tank-stored/transported" to the "fill" site. Now they can just take the calcium "concentrate", in a pick-up truck with-a-pump, and use on-site water to mix/fill. No "tank-truck" or trailer to deal with/store.
Also, there seems to be a bit of a problem pumping the stuff through the pumps that are ordinarily used for cal-fill.
Once the "Rimguard" is in, though, it sounds like the way-to-go. -- non-toxic, won't freeze, non-corrosive, and about 10#/gal.
I still haven't decided what I'm gonna do about tire ballast.
The Michelin techs, reccomend weights rather than fill,... but the JD manual says use weights AND fill for FEL work.
Ballast "aft" like on the 3-pt (say a 1000+# box-scraper) adds even MORE weight to the rear than the ballast-wt., because of the weight that is "levered' off of the front axle, which is GOOD when the loader is full, and BAD when it is empty.
I'm still working with figures/weights, trying to decide what I'm gonna do.
I don't want weight when not-desirable (wet-mowing), and I won't mess with bolt-on/remove wheel weights. and CAN'T change filled-tire weight.
Hmnn! /w3tcompact/icons/mad.gif
Larry
   / Decision Made! #15
Yeah Larry, don't you just hate those public blunders. I've had my share /w3tcompact/icons/blush.gif And yes, call me a wimp if I don't want to ride on solid tires /w3tcompact/icons/wink.gif
The other problem I've run into with relying on the box scraper for ballast is that it provides no weight when it's dragging on the ground. I've had traction problems (R-1s) pulling my scraper where wheel weights and/or loaded tires would have helped.
One thing you can definitely say about these tractors: There's no shortage of things to spend your money on once you own one /w3tcompact/icons/smile.gif
   / Decision Made! #16
Good point Rob, about the traction when the scraper is dragging. I'm counting on the overall weight of my rig being enough, for my soil conditions,
If I learn otherwise,I'll have to take another look at things /w3tcompact/icons/smile.gif .
Larry
   / Decision Made! #17
Hey guys,
In the ultimate quest for traction don't forget the effect tire inflation pressures have on both power management and soil compaction. /w3tcompact/icons/smile.gif
<font color=blue>Overinflated tractor tires are a common cause of poor tractive efficiency and compaction
Reducing tire inflation pressure to the minimum level required for a specific load will reduce wheel slippage,
Tires maintained at minimum tire inflation pressures transmit power to the soil through the largest area.
Increasing the contact area of tires reduces the pressure exerted by the tire on the ground.
The pressure exerted by a tire on the soil surface near the lugs is roughly 2 pounds per square inch greater than the tire inflation pressure.</font color=blue>
Of course the tire manufacturers recommendations should be followed to match tire inflation pressure to the load on the tire.
GOOD LUCK
DFB
   / Decision Made! #18
DFB,
I'll have to admit that I did not realize this. It makes sense to me regarding soil compaction, however, I would have thought that higher pressure would increase the rigity of the tread and thus increase its ability to "bite" into the soil. Also, for tires with a tight tread pattern, ie turfs, the higher pressure would keep the tread pattern open better to increase the tires ability to clean itself. I remember the debate over this regarding proper auto tire pressure when driving in the snow, and I think the consensus has now swung to higher pressure is better in this situation, since the tread tends to cave in at lower pressure.
BTW, great board! /w3tcompact/icons/smile.gif
AC
   / Decision Made! #19
AC,
Lower pressures makes sense to me for field work in soft soil. Looking for the largest possible contact patch to spread the load out and increase contact friction especially when using bar type tires. I'm not to familiar with ATV's but don't they run low pressures in their tires too and the tread is lot like turfs. Automotive tire tread patterns are much different than tractors and so is the application. I couldn't say that what applies to one scenario is useful for the other. After the Firestone tire problems they recommended higher pressures in auto type tires for highway use to keep the heat buildup from contact friction down. It certainly is interesting.
DFB
2011 John Deere 5075 4WD Agricultural Tractor (A52377)
2011 John Deere...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
(INOP) 2019 CATERPILLAR 336 EXCAVATOR (A51246)
(INOP) 2019...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2025 New/Unused Wolverine 72'' Skid Steer Ripper (A51573)
2025 New/Unused...
