Deck size = Pro's and Con's
   / Deck size = Pro's and Con's #1
JDTank
Platinum Member
Is there a downside to going with a larger deck, say the 60 inch 7-Iron on the X740 tractor? I already know about deck leveling and how the wider deck will scalp more on uneven ground, but I am wondering if there is anything else to consider.
Narrow gates are not an issue for me, there is only one gate I would like to make it through, but that gate is a definite no with even the smallest deck on this machine. Luckily I have a larger entrance I can use around the back.
So what are the pro's and con's of say a 48 or 54 inch deck, vs the 60 inch deck? I am concerned that the 7-Iron might be to much deck for the X740? That's a huge deck they crammed under there, and when it get's filled up with thick grass, I don't want any bogging down issues.
How about the 7-iron vs the regular yellow decks?
I would say 50% of the time I will be bagging, and 50% of the time it will be side discharge. I will not be mulching at any time so that is not important to me. I know the deck will need to come off about twice a month, once for cleaning and once for hauling supplies out to the barn (narrow gates) with a utility cart. In that sense, I can see the drive over 7-Iron being the winner.
   / Deck size = Pro's and Con's #2
I had a 62" yellow on a x495 and currently own a 72" seven iron on a 4310. If you have to move the deck after it is off, go with the yellow. You would have to abuse the yellow to wear it out and the weight difference/price difference is not worth it to me.
I bought the Gator blades Deere sells from Oregon. WORTH EVERY PENNY!! I bought a spare set. If you put those on you would likely never need the bagger. The yellow deck on the x495 was so easy to remove you would not believe it.
   / Deck size = Pro's and Con's #3
My 445 (similar to the modern day x700) has never had a problem powering a 60" deck. With a x740 you have the torque of a yanmar diesel, so it should never even bog down with a 60" in thick wet grass.
I know I just figured I would check and see. The 7-Iron is a huge deck and can process a heck of a lot of grass. Given I have never had the chance to drive one of the diesel X7xx series, I just wanted to be sure they have the oomph I would expect from a torquey diesel engine.
   / Deck size = Pro's and Con's #5
Also IMO the 7iron deck processes the grass much better than the yellow deck
   / Deck size = Pro's and Con's #6
I like the good old middle of the road 54" deck myself. I only have experience with the 54", so did a quick search for the 7-iron and this is what I came up with:
JDTank said:
- Does a bagger work on the 7iron deck? I really have no interest in ordering a tractor WITHOUT a 7iron deck, I have seen the difference they make and I feel it is a superior deck to the standard yellow decks.
JDTank said:
and the 7-Iron deck seems to do a lot nicer job then the regular decks that tend to clump.
I can be the first to admit I may have made up my mind per-maturely given my nature. I like to buy the best and say to **** with the rest.
In this case however, I worry about flipping the 7-iron over for regular cleanings. Then again, with the hose feature, maybe a good clean out with a putty knife isn't needed as often.
   / Deck size = Pro's and Con's #8
I have a 62 inch and like it alot. While it weighs a bit more than 200 lbs, I'm able to turn it over to clean and I'm not young at 61. The 7-iron is nice and I usually over buy. I do not know if it's a better deck in respects to cutting or just a beefier version. I think a guy should buy what he wants and not be criticized for his decisions, you can never go wrong with the best. I know my X744 is way more tractor than I need, but I also know it will meet my needs for pushing snow and I never will have to be concerned with underbuying or overwhelming it.
   / Deck size = Pro's and Con's #9
My take on the decks is rolling them on a concrete floor is very easy, wouldn't matter whether it was a 48 or 62 inches. I am short so reaching beneath to hook up the pto is a stretch and more difficult. I would consider the 60" 7 iron deck if purchasing a 2ws model.
   / Deck size = Pro's and Con's #10
Go too big and cut quality decreases. Don't feel 60" is to big though. The main reason is for being able to fit through your obstacles. I have a 54" deck because I have some tight areas that a larger deck can't fit through - or I'd go larger.
2012 GROVE TMS900E TRUCK CRANE (A58214)
2012 GROVE TMS900E...
CASE IH STEIGER 400 HD TRACTOR (A58375)
CASE IH STEIGER...
2016 DRAGON SAND CONVEYOR (A58214)
2016 DRAGON SAND...
golf cart (A56859)
golf cart (A56859)
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56438)
2019 Krause...
Willmar 4550 Wrangler Articulating Loader (A56438)
Willmar 4550...
