Deckover Tilt Bed Flat Top vs Beavertail w/ Ramps?
   / Deckover Tilt Bed Flat Top vs Beavertail w/ Ramps? #11
Criswell....Have you considered using the 24' Haulmark to haul your tractor with? Seems like the ideal situation being that you already own it as well as providing shelter for the times you are not using it. /forums/images/graemlins/smile.gif
Jon
</font><font color="blue" class="small">( </font><font color="blueclass=small">(Since you already own trailers, you have experiance and an idea how a trailer feels while you are towing it down the road.
Let's start on loading. If the trailer is wet, make sure it is level side to side. Your biggest problem is going to be the steel areas. Just take your time using a proper gear so you have good throttle control. You should be able to actually idle on.
But then, why even start with a wet deck? Save that for later once you have done some loading/unloading on a dry deck.
If the trailer ramps feel to steep, park the rig so it is going down hill slightly but be sure to block the trailer wheels and front wheels on the truck.
Under any conditions, enough machine weight on some trailers will cause the rear of the trailer to be pushed down and, all things being equal, the front of the trailer comes up picking up the rear truck wheels. Plenty of folks have gone for a short (or long) ride while doing this. You can put some blocks under either the trailer or the ramps depending on the makeup of the rig you eventually purchase. You will want to size the blocks so that as the trailer drops with the tractor weight, you can still remove them. The blocks would still prevent total removal of weight from the rear truck (and parking brake) axle.
There are some really well designed tilt deck trailers that eliminate ramps completely. You never have a lifting problem with them although with some designs, as the tractor goes over center, the deck will level and the first time may bother you. Most designs today use electric/hydraulics that soften that sometimes completely.
Depending on the length of trailer and machine, you may have deck room to play with. Start by having the trailer looking level with the machine on. When you drive down the road, you will find out if you need to adjust the tractor position in order to enhance handling. To much weight on the hitch can lighten the front truck axle to much causing sway. To far back, the weight comes off the rear and may cause sway.
It is a sad fact that the combination that you set up on occasion does not trailer well. You may end up using a weight distributing hitch. Cross that bridge when you get there.
If you are not well versed in tying down the tractor, I suggest checking out the threads on that subject. Basically though, you need to secure all four corners to prevent movement in any direction. If you have a rear mounted mower, etc. on then that must also be secured.
If you have proper tire inflation and your rig handles well in a straight line then curves should not present any problem.
)</font>
Thanks so much QRTRHRS!
I had about a 30 minute conversation last night with a friend who has an excavation business. Lots of equipment - dozers, excavators, backhoes, etc. Your reply sounds like you were listening in on his advice - just about item, by item!
I'm going tilt. I know they'll be a learning curve and some adrenelin moments, I'm sure, but we'll safely figure it out and get used to it. Took a few trips with the car in the trailer to find the "sweet spot". Now we don't even have to look to tell the car is not quite in the right spot. You can feel it from the driver's seat. This will be no different.
Thanks to all for taking the time to reply!
Andy
</font><font color="blue" class="small">( Criswell....Have you considered using the 24' Haulmark to haul your tractor with? Seems like the ideal situation being that you already own it as well as providing shelter for the times you are not using it. /forums/images/graemlins/smile.gif
Jon )</font>
Jon
The CUT sits too high, even with the ROPS folded. That would have been ideal!
But then you can never have too much equipment! /forums/images/graemlins/wink.gif
Andy
   / Deckover Tilt Bed Flat Top vs Beavertail w/ Ramps? #14
I have 3 Goosenecks and 1 Skid Steer trailer, 2 of the goosenecks have flat rears, the 3rd has a stepdown and my skidsteer trailer has tilt down ramps. I wished I had tiltdown ramps on all 3 goosenecks. Finding a ditch or low spot where I can pullout the heavy ramps to load a tractor is a pain. I use 2 Dodge's to pull these trailers and my Suburban. The 3500 Dodge works well on everything as it has duals. I have pulled a State Gravel truck 18,000 lbs loaded on my 3/4ton Dodge. I was over my safe zone with that load, it has singles all around. However 45 mph was my limit for speed. I have hauled my 1270 Case with my 3500 Dodge and it didnt know it was there! The only reason I dont have tiltdown ramps on my 2 yr old trailer is that I bought it for under $6000 at 1 yr of age. I know my Delta Dealer told me I would regrett not having the ramps. But I also am very happy with the deal I got from the 3rd party I bought the trailer from! If your going to haul a load every 6 months or so, your single tired truck and trailer would probably work for you. If your going to haul everyday, and your weights are high on the rating of your trailer you may feel safer with a 1ton rated truck even if it has singles that have a high ply rating tire. I run all 10 ply or higher rated tires! I would buy a tilt down ramped trailer if money wasnt tight! My ramps are sprung from loading tractors! I am sure others have ideas, which I may have missed. But a 3/4ton GMC with high ply tires should be a good fit for a 22 foot trailer rated for 14,000 lbs. My smallest trailer is rated for 12,000 and the others in the 22,000-24000 range and we use 215/85/16 tires on the dually or 235/85/16 on my 3/4 ton with about 65 lbs of air in them
Don
We're struggling with a decision here about which way to go on a trailer. There are pros and cons to both for hauling a TC40 and attachments (FEL, 7' MMM, 6' bush hog, PHD).
Here's the alternatives:
1) 22' Deckover w/ Tilt bed flat top (4' fixed in front, 18' tilt)
2) 22' Deckover w/ Beavertail and fold up ramps
Both are equipment trailers (14,000 GVWR) and are really well made with more than adequate suspension for what I'll be using it for.
Here's the concerns with each as I see them:
1) The trailer has dual axles with single wheels. My chevy pick-up (2500 HD with a Duramax) also has single rear wheels. There's something about having that much weight 3' in the air with single wheels all around that bothers me - especially on medium to high speed curves.
We're also concerned about the loading and unloading angle of an 18" deck that pivots to the ground from 3' up.
2) The concerns with this one are the same with respect to ride height, but the loading angle is a non-issue. The big disadvantage is having to fool with ramps!?!
We've considered a low boy with a tilt deck, but having fenders in the way of all the uses there could be for this trailer seems like your shooting yourself in the foot.
Any expert opinions? Anyone with some experience with one or both of the alternatives?
Thanks!
Andy
   / Deckover Tilt Bed Flat Top vs Beavertail w/ Ramps? #15
I am back again, We are going to add another new trailer fairly soon in that 14,000 lbs range. It will be a Deckover, Tiltbed trailer of some sort probably a PJ or Delta. or we shall build it ourselves. It shall have the 7000 or 8000 lbs axels depending on what deal i can make on axels. Now if I build it I will put triples on it with 16 inch tires. We own a Salvage yard so we have all kinds of parts just laying around our yard and have uses for them all! Another thing you may want are D-rings mounted into the bed of the trailer. Makes putting you chains on your load easier! At least 6 of them! Provisions for a winch may be good! I have winched cars out of a backyard many times to fix or repo! I like gravity tilt trailerbeds, as hydraulics get real stif at times in the winter months. But I am on the 48thlattitude!
Thanks!
Andy
   / Deckover Tilt Bed Flat Top vs Beavertail w/ Ramps? #16
I had a 9 ton, tri-axle, deck over, beaver tail.
I liked the trailer.
Easy to load, I could haul anything my truck could pull.
Pintle hitch.
Only negative was a tight turn on tri-axle is no fun as you end up dragging an axle, just too many wheels to turn tight.
I also did not like the pintle as I did not have weight leveling nor sway control.
The deck over beaver was excellent when loading and unloading.
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2017 VOLVO VNL TANDEM AXLE DAY CAB (A59575)
2017 VOLVO VNL...
2019 Chevrolet Silverado High Country (A56436)
2019 Chevrolet...
Hatchback (A59231)
Hatchback (A59231)
2021 Deere 333G (A53317)
2021 Deere 333G...
More info coming soon! (A56859)
More info coming...
