BHD
Veteran Member
is it brick or brick veneerer,
if it is just veneer it will come down easy, as it is just a single row of brick with some ties to the wood framing,
a brick wall is made of two or three layers of brick with a thickness of about 8 to 12 inches to make up the wall,
it is veneer, take it down like a frame house,
If a true brick wall, one will most like want to use a excavator to knock it down and then haul it off or bury it,
some depends on what you think you want to salvage, one can take a hammer and brick chisel and take it down brick by brick if wanted to, but the time would be a lot of hours,
(in my experience it is hard to salvage lumber for really reuse) what I have found is to clear off the edges and chain saw the joists a few inches in from the rim joist and drop them instead of pulling thousand so nails, yes the lumber is shorter, but kinda a trade off of time and value,
