Deep well submersible pump question
   / Deep well submersible pump question #11
A 3-wire pump uses 4 wires because they added a ground wire back in the 90's. A two-wire pump uses three for the same reason. The 4th wire (or 3rd) is just a ground.
You should be fine with the franklin box, but they can't tell you that. Something about CYA. I would at least try it and see.
   / Deep well submersible pump question #12
They didn't need stinking ground wires back when my pumps were first put in[I guess],cause there are only two wires running into house:D,,
Works,feel a little tingly sometimes,,but just figured it was the high blood pressure pills working and doing good things to me.
2015 Ford Taurus SE Sedan (A55853)
2015 Ford Taurus...
2018 Wacker Neuson RTSC3 Trench Compactor (A54865)
2018 Wacker Neuson...
2025 68in Dual Cylinder Grapple Skid Steer Attachment (A53421)
2025 68in Dual...
2011 NISSAN FRONTIER EXTENDED CAB TRUCK (A51247)
2011 NISSAN...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
