Deere 175 fuel problems?
   / Deere 175 fuel problems? #11
I have a JD 175, 14HP Kawaskaki. It will run OK for a minute, then start to sputter. After another minute, it will only run on choke. What is the deal? There was water in the fuel, but STP and another product were used to push the water out. It sputtered for a few minutes then. I let it run for 15 minutes, and it would at any setting. I shut it off,and it hasn't run right again. Do I have to drain the tank,blow out the line, clean the fuel pump and carb, or replace the fuel filter? I am going to sell this, so I would like to get it running.
Also, how much should it be worth as is AND fixed? It is a 38" hydro. Thank you for any and all replies. /forums/images/graemlins/confused.gif
before canning the carb I would remove the carb and soak the complete carb submerged in sea foam. seems the carb's main jet and or the vent tubes are clogged. I only run non Ethanol in my small engines. and if not going to use in a while I shut the fuel valve off and run carb out of fuel to store for a while
   / Deere 175 fuel problems? #12
The OP posted about his JD 175 trouble over 11 years ago so let's hope he got if figured out few years ago.
   / Deere 175 fuel problems? #13
ha ha. I have a bad problem of not looking at the post dates. lets hope he did get it fixed
   / Deere 175 fuel problems? #14
It's probably ready to be fixed again by now, so we better keep the thread going....
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2012 CHEVROLET 2500 HD SERVICE TRUCK (A51406)
2012 CHEVROLET...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2016 Peterbilt 320...
1995 VOLVO BM A25C 6X6 OFF ROAD WATER TRUCK (A51246)
1995 VOLVO BM A25C...
