OP
forestcreature1
There is a monroe county in Wisconsin... or are you elsewhere in a monroe county..??
Hope to see more pics... and that you will be happy with this tractor.. what is the primary use for it?
Southern IL for the county
Thanks for the good wishes!
Primary uses (keep in mind that I have a 3046r/loader/cab & a massey ferguson 2605h [2wd/open station]:
1) plowing, the "r" has r4 tires and they were not meant to plow with.
2) lake work day, the cab gets in the way of communicating with the shovel crew
[when we have hot weather work day, I will be using the a/c in the cab]
3) hydraulic dump wagon [filler with the 'r', dump with the 'd'] <-- bad sign that I am making up rhymes...
One thing that I would prefer to have is draft control - but I suppose then I would have to go find some old deere 3pt mounted plow..
The MF2605H has draft control that works perfect with the 1947 Ferguson 3 bottom plow [which is why I bought the H]
((side trivia - back in the day, one brand of plow did not play well with another brand's draft control -- probably still true if you can find a compact w/draft))
If you are not in clay or rocks, you probably won't know/care anyway.
I have plowed with the 'r', but it is a pain with the 1943 Ferguson2 bottom due to the lack of traction [plowing clay here] and the r4 tire won't fit in the furrow.
Now, I bought the 'r' [and also had a 3032e before that] without any field work involved.
So they were properly configured for their uses, landscaping - mowing - road maint.
Old farmer died, I took over the lease of one of our four fields (3 acres) since the 'new' farmer [nephew of the dead one] could not get his massive deere equipment back here to the field next to me due to trees & the narrow road on top of the long dam.
I am using the field as 'tractor play pen' more than anything else.
I started off with a 4100 gear, and it was a great little machine.
After many years, I needed more mass to deal with rip-rapping the lake shore, so went to the 3032E.
Allergies flared up, eyes would swell shut, so traded that in for a cab. [3046R]
Life is good with a cab [in case anyone was wondering]
<reread farmer thing in case anyone's memory is as short as mine>
Then Deere came out with the D and was touting it's pulling power.
Paid off the car in Aug, so there was "deere money" available....
I plant sweet corn in 6 row blocks [think chess board using rectangles] alternating plots in the field to not plant in the same plot each year.
I plant a block per weekend over the spring to get corn on a regular basis.
Neither I, nor the food bank have any refrigeration, so I pick & bag a bushel at a time. [pick on Sunday eve, drop off Monday on the way to work when I have some come up]
The whole field is over-seeded with cowpea to help the soil.
I also started with sunflower this year since our spring was so messed up, and that turned out well. (just going to mow & till that under).
IF the 'd' pulls hard enough, I may go look for a pull type plow [3 or 4 bottom, maybe a 5] to see how that goes.
(for those who want me to go no-till, buy me a no-till system, I accept donations!)
Lake work day is Sat, so if things all line up, I will be able to report how it goes.
(they don't work in the rain & if it does rain, I will be in the cab)
On non-lake-work-days, I maintain the semi-oil-chip-gravel road by myself in the cab when the pot holes get too bad.
(dump and back drag cold patch)
OH - one last thing.... When everyone is out mowing, and it's hot, we all wave at each other (I mow a lot of common ground) and I have noticed that the other lake people do not use as many fingers to wave at me as they used too....
I do know that my tractor is #1 though [I can count fingers...]
