Deere 455 - smell some coolant while operating
   / Deere 455 - smell some coolant while operating #1
theedudenator
I cant tell if it is using any coolant.
I really never added any to the overflow bottle.
I get a wiff of smell when I am mowing.
Is there a weep port on the water pump?
Anywhere else I should look.
I do get a puff of white smoke when I start it up, never comes back.
I checked the glow plugs, I have voltage to them.
I replaced my dash gauge assembly, temp gauge is still not working.
Going to try to check it today.
   / Deere 455 - smell some coolant while operating #2
If your water pump is dripping from the weep port, o-ring or gasket you may not see it since it seems to hit the lower pully. Look for white areas of dried coolant.
My X748 had a leak in the lower radiator pan. Replaced radiator. Now the water pump is dripping. That will have to be replaces soon I guess.
   / Deere 455 - smell some coolant while operating #3
If your not loosing coolant then its just coolant bottle venting the odor as warm coolant goes in it as the engine heats up. I get the same thing on my 3320 tractor.
   / Deere 455 - smell some coolant while operating #4
If it were me, I would pressure check the Radiator. This would determine, if you have a leak, and where the leak is. Perhaps your local Advance Auto will loan you the pressure tester by making a returnable deposit?
Landhonor 40gal 2 Stage Air Compressor (A47371)
Landhonor 40gal 2...
WALKING BEAM, PITTMAN & HORSE HEAD (A48992)
WALKING BEAM...
2010 UTILITY 53X102 DRY VAN TRAILER (A50046)
2010 UTILITY...
2017 Dodge Ram 4500 4x4 Crew Cab Reading Service Truck (A48081)
2017 Dodge Ram...
2012 KENWORTH T800(INOPERABLE) (A48992)
2012 KENWORTH...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
