Deere 4720 capabilities
   / Deere 4720 capabilities #1
Tritonman
I am dealing on a 4720 and am curiousm about the limits you guys have pushed it to. I am talking about how wide of disc etc how big of mower
I habe a four row planter i want to pull with it that recommends 50 pto hp so i will be pushing it there
I have a 3320 cab for sale if anyone is interested
   / Deere 4720 capabilities #4
The smallest Hp 5000 series will probably be less money than the 4720. You'd get a bigger frame, more weight, and about the same power. Look at it quick, it could be an eye-opener. Apparently you don't plan to mow your lawn with it, so get the Ag tires. The R4's are not good for ground-engaging work such as discing.
   / Deere 4720 capabilities #5
For what you want to do I'd be looking at the 5000 and 6000 series tractors -- heavier and more hp depending on model.
   / Deere 4720 capabilities #6
I have a 4320 with R4's. I pull a fairly heavy 8ft. Priefert 24x20 disk, and it does well. However, in soft dirt with the disks burried, it's about all the tractor wants without beginning to struggle. I also use a MX-6 rotary cutter. In 90% of situations, it handles the MX-6 with ease (although it can make the front end a little light). I would love to pull a 10ft rotary cutter, but I think 40hp at the pto is pushing things a little. Your 4720 should handle a 10ft pull behind rotary cutter fairly efficiently unless you are in real heavy grass. I also think the R4's will limit your abilities vs R1 tires. I can't advise about planters because I have never pulled one.
Its a 2008 450 hrs cab radio five hydraulics top n tilt rear lights 60 in belly mower and choice of ag tires or turf cx loader pallet forks. 24 thousand in north dakota hood guard on it also. Basically perfect
   / Deere 4720 capabilities #9
i know someone who lost a 5000 series tractor to a fire and replaced it with a 4720. He was disappointed with it and now wants a bigger tractor.
   / Deere 4720 capabilities #10
What size 5000 series tractor, and what tasks was he expecting the 4720 to perform? The larger 5000 series are definitely in a different league than the 4720. However, the smaller 5000's, although much heavier and better for ag applications, will have similar HP.
Road Brute Flat Deck Trailer (A50514)
Road Brute Flat...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A52141)
2020 INTERNATIONAL...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A51222)
2014 INTERNATIONAL...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
2013 Isuzu NPR-HD 16FT Reefer Box Truck (A50323)
2013 Isuzu NPR-HD...
