Denver-area power company "locks" smart thermostats....
   / Denver-area power company "locks" smart thermostats.... #61
Ah, naw, not yet at least.. Better read the report.
Really? Not just reading, but comprehension is required apparently. "The contamination discharged into the Columbia River is a potential threat to fish and wildlife and their habitat."
Not my job, but when i worked at the reservation, i talked to people that monitored the leakage, they said that they could "finger print" the reactors and tell you from which reactor the waste was generated.
   / Denver-area power company "locks" smart thermostats.... #62
Knock on wood, my hot water heater is still going from 95. Replace an element. I've sucked the crud out of the bottom a couple times, the second was when the element burned out, probably because i didn't clean it out in time. The sediment was over the element.
   / Denver-area power company "locks" smart thermostats.... #63
I do a drain on mine monthly and same with the rentals.
   / Denver-area power company "locks" smart thermostats.... #64
On subject, I'd never have a smart thermostat, bad enough having a 'smart electric meter' that the power company has control of.
While its not a requirement to have an HVAC system....smart t-stats can be pretty handy.
Just like going from a flop phone to a smart phone.....where you have camera, compass, level, and infinite internet wisdom at your fingertips....t-stats have evolved.
I have an ecobee. And while 99% of the time its just used to select between heat/cool/off, or set a temp....it has alot of other unique features.
First, I can control it from my phone. So If I shut it off when we go on vacation or even gone all day, I can turn it on a few hours before coming home. And while not really efficient for heat-pumps....a daily setback when at work is quite efficient on other heating sources. Cant do that with an old-school t-stat. And I can also set a timer on the FAN only. Where as old-school its either on, off, or auto(run when HVAC runs). Bu I can set a timer on mine in 15min increments to circulate the air in the house (even out temp between basement and upstairs) and not have to worry about forgetting to shut it off.
Not trying to sell you on a smart t-stat....but they do have their merits
   / Denver-area power company "locks" smart thermostats.... #65
I never drain and typically 20+ years and sometimes over 30 years... all natural gas.
I've found what shortens life is frequent high temp cycling.
Put all new heaters in a 6 Plex... the one that went at 7 years was a large family and kept the heater on max to get more hot water for all the showers each day...
   / Denver-area power company "locks" smart thermostats.... #66
   / Denver-area power company "locks" smart thermostats.... #67
Actually, I'd prefer a flip phone with no 'features' but calling. I don't care for all the 'app crap' my Galaxy has and never use the stuff anyway. In fact I'd rather not even have a cell phone only reason I do have it for necessary communication. I must prefer my SAT phone but a SAT phone is not only expensive to own, it's expensive to use. Air time is costly.
   / Denver-area power company "locks" smart thermostats.... #68
Mines the same. It heats water with the excess heat before its returned to the ground. I have a preheat tank and a tank that gets the water hot enough for use in the house. Very efficient.
Jeff
ROI on a 'water furnace' for us in out of the question. Too old to realize the savings. Of I was 20 years younger, I'd have one.
   / Denver-area power company "locks" smart thermostats.... #69
We put our geothermal in when the government was giving 30% tax incentive. Our heatpump was fading fast so I needed to replace it anyway. 11 years ago and I would say its paid off in savings.
Jeff
2008 Ford F-450 Chassis Truck, VIN # 1FDXW46R48EC52709 (A54865)
2008 Ford F-450...
Water Pump (A54865)
Water Pump (A54865)
New/Unused CFG Industrial MH12RX Mini Excavator (A54865)
New/Unused CFG...
SAKAI SV544 SMOOTH DRUM ROLLER (A52706)
SAKAI SV544 SMOOTH...
2003 Chrysler Town & Country Van (A55758)
2003 Chrysler Town...
19002 (A55853)
19002 (A55853)
