Detached Garage
   / Detached Garage
I've added a few more pics of the Pole Barn. The roof is dried in, the subfascia is on and the overhead door is installed. The overhead door has cedar trim overlay and faux hinge brackets and handles to give it the appearance of old style swing barn doors. I'm real happy with the way it turned out.
   / Detached Garage
There's another picture up of my pole barn. Most of the trim is on, and the roof shingles are on. I'll add a bunch more pics next week after the staining is finished.
   / Detached Garage #13
You've got some great pics on your website. I'm really enjoying following your progress.
   / Detached Garage #14
bandit67, Really a beautiful pole barn , Nice JOB! /forums/images/graemlins/cool.gif
Love the Doors and T brackets on the side roof-over posts.. /forums/images/graemlins/smile.gif
   / Detached Garage #15
Great looking barn! It's going to take you a lot less time to fill it than it takes to build it.
   / Detached Garage
Thanks for the compliments, guys.
The barn's been fairly full since the roof paper was put on and the doors could be locked. We had to stash all sorts of stuff that was in the house and garage when we moved out for the house renovation. I'll put some pics up this weekend of the house. We're in the middle of the demo stage, so there's no turning back now - there isn't much more than a partial shell right now. /forums/images/graemlins/shocked.gif
   / Detached Garage #17
Ed; Very nice building. One question, how did you make the sectional doors? I really like them. /forums/images/graemlins/cool.gif
   / Detached Garage
The big front door is a 16'x8' overhead sectional door. The door company builds an insulated door with rigid foam core and dimensional lumber for the structure of each panel sandwiched between masonite sheets (similar to the doors that a production builder would put in a house, but much heavier duty). Once they have the door built, they then apply 1x cedar trim boards (that the owner/builder supplies) per my design. Black powder-coated faux strap hinges and handles are applied to complete the appearance of swing-out barn doors.
A number of the local overhead door companies have been doing these types of doors for 20 years now. I've spec'd these often times for multi-million dollar new homes. Some of the door companies are national, so these types are available in other parts of the country.
My door was done by Overhead Door Company, but I also got quotes from Raynor Door, and a few others. These doors are not cheap - this 16x8 ran $3,000 installed with opener, remotes, etc. It has a heavier gauge, 3" galvanized track (standard door tracks are 2"). Prices from other companies ranged all the way up to nearly $5,000 for the same door. Many of the companies are now offering similar styles of doors out of their catalogs in masonite clad, which can be painted, and in steel insulated doors for quite a bit less money. But the cedar clad, stained doors are the most realistic looking, and thus, most expensive ones.
I will be putting a similar door on the garage attached to the house, but it will be 18'x8'.
   / Detached Garage #19
Ed; How big of a dooropener do you need? Also, I couldn't see any fasteners on the outside. I suspect the boards are thru screwed from the inside thru the panel frames? /forums/images/graemlins/cool.gif /forums/images/graemlins/grin.gif
   / Detached Garage
The opener on my door is only 1/2 hp, but it is a heavier duty model provided by the door company - the standard residential Lowe's or Home Depot model may work for a while, but will eventually fail. Other door companies recommended their own heavy duty 3/4 hp opener.
The cedar trim overlay is attached with liquid nails and finish nails from the outside.
John Deere 843 Corn Head (A50514)
John Deere 843...
2025 GIYI Dual Cylinder Hydraulic Grapple Plate Bucket Skid Steer Attachment (A50322)
2025 GIYI Dual...
2018 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2018 CATERPILLAR...
Morooka MST 660VD Tracked Dump Truck  Only 30 Hours (A52128)
Morooka MST 660VD...
Irrigation Pump (A52128)
Irrigation Pump...
NEW HOLLAND LB75B BACKHOE (A51242)
NEW HOLLAND LB75B...
