detent valve
   / detent valve
I wouldn't even know where to start. I looked at that link and where and how would you mount this thing and how does it work?
   / detent valve #13
That valve is a selector valve, allowing you to select two different hyd circuit.
Just bolt the valve in a suitable position for you to switch between two circuits.
Pressure hose goes in one side, and provides for two outlets. Each outlet goes to another valve downstream.
   / detent valve #14
I'm thinking you're going to learn a bit more about hydraulics than you ever really wanted to, Alaska..:) It'll make sense in the end, lots of people here with enough experience to walk you through the tricky parts.
Sean
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
1287 (A58374)
1287 (A58374)
2022 Behnke Trailer (A55973)
2022 Behnke...
Water Line Hose (A59076)
Water Line Hose...
14 Gun Fireproof Safe (New/Unused) (A59225)
14 Gun Fireproof...
23ft x 22ft Double Garage All Metal Building (New/Unused) (A59225)
23ft x 22ft Double...
