Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,141
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
I purchased a used Farmtrac 360 about 3 months ago during the hottest part of the steamy Alabama Gulf coast summer and it ran great. It did make a funny noise for maybe 5-10 taps that sounded like a ping or detonation the first time we went to test drive it and promptly stopped, the sound did not return.
that is until this weekend. It is still warm, but probably 10 degrees cooler than when we first got it. The noise I don't know how to explain it, but I will try. Basically after mowing the grass for about 2-3 hours running in the 2400 rpm range, I was done mowing and needed to do some FEL work. So I turned off the PTO lowered the RPMs and started pushing stuff around. Within a few minutes it started the tapping/pinging/detonation noise.
I have rebuilt engines before so I know what all the parts look like, but I really don't have much experience with actual engine troubleshooting I am just a take it apart and replace everything that is out of spec guy.
Anyways if I had to guess it sounds like what I would expect a collapsed lifter to sound like. A hard TAP sound. It sounds sort of like someone is whacking some part of the engine with a ball-peen hammer. Now that said it is very obvious that it does not occur every RPM. if the engine is turning 2000 rpms the tap does not happen that frequently. It happens pretty fast but I could almost snap my fingers as fast.
If I turn the engine off and check the oil, by the time I crank it back up the noise will be gone. The noise probably won't return for the duration of the work. I did notice once it started tapping when I had driven the tractor up on the brush pile and it was at an angle that made me think it may have been a lubrication problem, but I backed it off the pile and the noise continued. I turned the tractor off counted to 20, restarted and the noise was not there.
So I am wondering is this maybe caused by a hotspot in the engine causing "detonation"?
I am running street deisel, because I have gotten aggrivated with the questions I get when I try to buy offroad deisel. For some reason the clerk always gives me a snoody look and ask me what I am putting the deisel in which really just gripes me.
So I was wondering if anyone else has an idea what this problem could be?
Does it sound like fuel related detonation?
Is it ok to use street deisel or should I be buying offroad deisel?
What should I try?
I want to reitterate this problem has only occured when the engine was ran at a continuous high rpm for a while then the rpm lowered.
Your problem is not likely to be fuel related. I can think of two possibilities: a leaky injector, or a problem with the advance/****** mechanism in the injector pump. The former, in my opinion, is more likely.
If this were my tractor, I 'd start by putting in a good injector cleaner additive( something by Stanadyne possibly) in the fuel and see if that cured the problem. If it didn't, I'd pull the injectors and have them checked and repaired or rebuilt as necessary.
If your tight on funds, you could by one new or rebuilt injector and try it on #1cylinder and if that didn't improve things, move it to #2, etc and check it out that way.
You could try to find the problem cylinder by cracking the injectors one at a time when the problem occurs but that's a pretty messy deal.
You want to sort this out because if it is a leaking injector it can lead to some costly damage( burned piston crown).
Hope this helpss you.
