Deutz 1011F Parts Diagrams for PT 1850
   / Deutz 1011F Parts Diagrams for PT 1850 #11
deutz said:
Ken,
If I can also assist, the number on the bottom right of each of your Deutz Engine Diagrams is what Deutz refers to as the ETL # IE.. 0510 1472
All Deutz Distributors and Dealers can insert this # into their SERPIC System and bring up the identical page that the customer is looking at. All else failing, the customer only has to provide the serial # of the engine, and the same can be done.
Jack
DAC Industrial Engines
Deutz Distributor
macmasterj@dacie.ca
Welcome to TBN! We'll have to introduce you to Jack from Robin. :)
   / Deutz 1011F Parts Diagrams for PT 1850 #12
Dear Ken,
Great labelled photo! By the way, the lever just above the throttle cable is a shut off lever.
All the best,
Peter
ksimolo said:
Hi Peter,
With respect to one of the pictures you mentioned (reposted below), what is the gold colored canister above and to the left of the fuel pump? It has the blue colored ring electrical connector on it. On the Deutz parts diagram, they show a blank plug in this location.
Curious minds want to know!
Ken
   / Deutz 1011F Parts Diagrams for PT 1850 #13
Dear Ken,
I was speaking to Terry this morning. He says the little one is the low oil pressure sensor, and the gold canister is the oil pressure sender.
All the best,
Peter
ksimolo said:
Hi Peter,
Ken
Hi Peter,
Thanks for the information! I will update the picture.
Ken
1985 Ford Ltl9000 Tender Truck (A56438)
1985 Ford Ltl9000...
UNUSED MOWERKING SSRC 72" HYD BRUSH CUTTER (A58376)
UNUSED MOWERKING...
2007 Kenworth T800 Tri Axle Day Cab Truck Tractor (A56858)
2007 Kenworth T800...
KATO Light Diesel Generator (A55272)
KATO Light Diesel...
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
2015 Mitsubishi FE180 Cab and Chassis (A55272)
2015 Mitsubishi...
