Dexter MH electric brake replacement
   / Dexter MH electric brake replacement
Yep...that's exactly what I plan to do. I determined that they are 3" axles. Found a guy to weld them on so will be ordering the parts from ertrailer. Got one side ground off last night and will do the other today.
Doug
   / Dexter MH electric brake replacement #12
I would have defiantly gone the route of just bolting on new axles. The only thing you have managed to "save" was some axle tubes that im shure are good and rusty.
Be shure to post what it costs you to do your rebuild. I think it would be usefull for others who come across MH axled trailers and have questions about them (several times a year around here).
Do you have a source for new rims and tires lined up? (like some old chevy wheels or something?)
   / Dexter MH electric brake replacement #13
Dexter Axle - Trailer Axles and Running Gear Components - FAQ'S
AXLES - Can mobile home axles be reused?
The Dexter MH (mobile home) type axle is designed for limited usage in the delivery of manufactured homes and has a one-time limit use. The axle has steel forged spindles that are not precision ground. The brake assembly is welded onto the beam and not intended to be field replaced. Additionally, the bearing package is smaller than the more expensive service type axle. Most MH axles are also equipped with a single leaf spring suspension for very heavy loads. We do not have components that would convert MH axles to serviceable assemblies.
   / Dexter MH electric brake replacement #14
You reuse the brake drum, wheels, and tires. All you do is replace the welded on plate that holds the brake shoes with a ring (welded on) that allows you to bolt on a complete brake assembly.
It's about $65 per wheel.
   / Dexter MH electric brake replacement #15
Dexter doesn't like their MH axles reused. I bet a part of the reason why they don't like their axles being reused is that is money out of their pocket. The last time I checked for $125 I could get a MH axle, springs and tires/ wheels from a MH dealer. Hard to compete against those kinds of prices with new axles. If Dexter really was so concerned with safety they would lease the axles out and require their return.
7ft Workbench (A57454)
Kohler Diesel Pull Behind Generator (A55272)
Kohler Diesel Pull...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2012 DOOSAN G25 GENERATOR (A58216)
2012 DOOSAN G25...
12' Container W/Side Door and Window (A57149)
12' Container...
2023 JOHN DEERE 325G SKID STEER (A52709)
2023 JOHN DEERE...
