diamond plate flooring for an RTV --
   / diamond plate flooring for an RTV -- #11
Eric,
Diamond plate is OK and looks nice, but moisture can get under it and with these types of vehicles it could cause rusting of the floorpan. Mats are not much better as they can get grit under them and do the same thing. I had a diesel Gator which my dealer really slickly modified last year. I have since sold the machine, but we diamond plated the cargo box rails, which looked good, and did the spray on liner for the floopan area and cargo box itself. It really looked nice and was very tough. No rust there. As for price, it really was not too bad. He has gotten an XUV Gator which he would like for me to purchase (twist my arm). He is spraying the bed and floorpan on this machine also. Is really convenient, just hose it out when you need to. It is grippy, looks sharp when done correctly and is really not that expensive. Just something to contemplate.
John M
   / diamond plate flooring for an RTV -- #12
sticky said:
If you think about it, Diamond plate is the worste material you could use for an area you will be stepping on. It is slippery when muddy and wet. Rhino lining is the only whay to go unless you are a rapper and looking for bling bling!
Sticky, you are absolutely right about "slippery when wet." I bought a pickup bed liner from TSC and cut it to fit in the bed of our Mule and also make a floormat. It is perfect! Diamond plate looks nice, but if it isn't rubber diamond plate, it doesn't belong under foot.
   / diamond plate flooring for an RTV -- #13
Have the diamond plate on my rtv. Its garaged a lot and fairly dry here in N CA so rust issue is minor. I like it as does my 120# lab. He hardly falls out on slopes anymore:D
2015 Jeep Compass SUV (A50324)
2015 Jeep Compass...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
JOHN DEERE 17P LOT NUMBER 241 (A53084)
JOHN DEERE 17P LOT...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
LMC LOT NUMBER 141 (A53084)
LMC LOT NUMBER 141...
