Did I break something? Need help from the hydraulics gurus!
   / Did I break something? Need help from the hydraulics gurus!
Ps is this an electric over hyd valve, or straight mechanical valve? Ie fly by wire or not?
Mechanical; joystick attached to valve by cables.
   / Did I break something? Need help from the hydraulics gurus! #22
I also think it's the load check valve, it got broke or flaten the spring.
How do I check/test the check valve?
And wouldn't the boom just drop whenever there was no flow to the cylinder if it's a busted check valve? As I mentioned earlier, the loader stays up as long as I stay clear of the joystick.
   / Did I break something? Need help from the hydraulics gurus! #24
The load check only comes into play when you are shifting.
The purpose of the load check is to prevent the load shift when you move the levers, and also prevents back flow to the IN port.
2025 CFG Industrial M-AG (A50123)
2025 CFG...
2020 CHEVROLET W4500 16FT REEFER BOX TRUCK (A53426)
2020 CHEVROLET...
2015 Ford F-350 Dump Truck (A51692)
2015 Ford F-350...
CATALOG IS A GUIDE ONLY!! (A50775)
CATALOG IS A GUIDE...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
