Did I hurt my PTO shaft?
   / Did I hurt my PTO shaft?
"I suggest you see how easily the two halves of the PTO shaft slide (collapse and extend). If they slide pretty easily, you probably did no harm."
Good point. I did extend/retract them and they moved freely like normal.
"You could give it a more rigorous test by separating the two halves, turning one half 120 or 180 degrees"
That is a good idea.... I didn't do that but will try next time I use it.
"Any chance the mower is shaking cause none of the angles on the a-frame are the symetric?.. No offense.. but the thing looks like a pretzle.. the lift pins both look like they point in a different plane.. etc"
None taken. The hog was free and yes... it isn't quite right. But it hooks up fine and cuts without fail.
It probably isn't shaking anymore than any tractor running a cutter.... I think most of it was in my head considering the little incident that happened right before using it.
Thanks everyone!
   / Did I hurt my PTO shaft? #12
Might I also suggest that you consider straightening that A-frame and horizontal brace? And perhaps new lift pins while you're at it. I'm bettin' that straightening that stuff out will dampen some vibration too.
I also noticed the flexible toplink bracket is missing. Some might call it a floating toplink bracket. Either way, you'll get a lot more even cut when that's replaced.
//greg//
   / Did I hurt my PTO shaft? #13
RoyJackson said:
........That would put a pretty severe load on the tractor and cutter gear box, don't you think?
No I don't. The shaft will bend back with just a couple hundred pounds applied in the middle - way less than it would take to hurt either the tractor or mower. If anybody thinks this is too much force, then they must think the original bending of it must have wrecked all these parts too, right? Of course not. Its just the same amount of force that it has once resisted just fine - but applied the other way. I've done a lot of successful repairs like this - really no big deal. But I suppose if someone has never done anything like this, it can seem scary. BTW, I have three presses of different tonnage. I actually do know what I'm talking about.
And to //greg//: If there is play in the bearings that support a shaft, then imbalance can agravate an oil seal leak. But the shaft has to be loose in its supports already. Seals leak when the path of the sealing surface becomes eccentric. If the bearings are not worn and if they fit right, that doesn't happen. Anyway, what's bent here is the shaft, not the yokes. The repair forces needed are actually quite low.
   / Did I hurt my PTO shaft? #14
I don't like the idea of it, Rbargeron. Just my two cents, but it sounds like it didn't get bent in the first place, so it is a mute point.
As far as checking to see if the front half of the pto shaft will slide in/out easily, considering this one appears to be stored outside, you might want to slop a little grease on the two halves and then try it again should it ever become hard to slide before deciding that the shaft is bent.
David from jax
   / Did I hurt my PTO shaft? #15
I disagree with you...that triangular shaft should be pretty rigid.
However, I've nothing to back this up other then a gut feel and a fair amount of experience using or directing use of hydraulic presses (usually to straighten components after processing).
Well, seems like a moot point now anyway...
   / Did I hurt my PTO shaft? #16
Hmm.. I disagree.. i fthat shaft has a deflection so that it places more load on the beairng in one direction.. then it will eventually cause a failure.
I have a couple rebuilt steering boxes that took out top thrust bearins due to a bent / wobbling' worm shaft... IE.. uneven side to side loading on a bearing is not good for it..
Soundguy
   / Did I hurt my PTO shaft? #17
The problem I see with this sort of advice is, it's being given as if you KNOW the strenght of the gear box, as if you KNOW the strength of the pto assembly, and as if you KNOW how much force would be needed to bend and/or "un-bend" the shaft. Again, can you say without reservation that it took a force EXACTLY the same to "un-bend" as it did to bend that shaft?
There's a possibility that (if the shaft was in fact bent) the forces needed to bend it were quite considerable. Those forces used to bend the shaft in the first event may have been with-in ounces of what may have taken to have broke something.....Maybe not. You don't know. Neither do I.
A few years back, I bent a pto shaft when I raised the 3-point hitch after hooking up a mower for the very first time. I didn't realize it, but the pto shaft would hit the front edge of the mower deck while the hitch still had a few inches of lift yet remaining. This little oversight put a 2" deflection in a new shaft. The 3-point hitch on this tractor has the capability of lifting nearly 3000#. The mower was 1200#. So, that left 1800# of capacity un-used, and that force was applied to the shaft. It bent oh-so easy. Or so it seemed.
At some point in that event, there was as much as 1800# of loading divided between the pto shaft and the gear box. The "fulcrum" in this event was the leading edge of the mower. That point was approx. 2/3rds of the way between pto and gear box, closest to the pto.
Armed with that information, could you tell me EXACTLY how much load was applied to each point? Could you tell me EXACTLY how much force each point is capable of withstanding as a side load? CAn you tell me beyond any question that those points could take a SECOND loading equal to the first?
I can't and I was there. You weren't and you would HAVE to be speculating. I can't tell you and I know what sort of mower, tractor, and shaft I was dealing with. You don't know what sort of mower, gearbox, or shaft was used in MY case OR the one mentioned in the original post. Again, you would HAVE to be merely speculating.
Given the FACT that you're speculating on the events, without even knowing facts that would be VERY critical, that speculation is unfounded, and therefore, TERRIBLE advice, potentially destroying someone elses mower or tractor, or even possibley injuring someone.
Your idea MAY work. Just as likely, it may end in disaster. Not the sort of free advice any of us are looking for.
And by the way, when I took my bent shaft to a machine shop to be straightened, it required nearly 3000# of force (in a hydraulic press) to bend it back straight IN A CONTROLLED MANNER.
NO ONE can make a statement as absolute fact without having the facts.
   / Did I hurt my PTO shaft? #18
Before you all get out the tar and feathers, I did have a pretty good idea what kind of shaft we were talking about - the drawn tube "triangular" style that's been common the last 20 years or so. There are several sizes - this mower would come with maybe a class 3 or 4 shaft. I have straightened a shaft like this - and the force needed was not very high. My suggestion didn't come with an air-tight, bullet-proof, iron-clad guarantee (asking for all that is a little dumb under the circumstances) but anybody with some common sense could try it and see how it went. I think that's exactly the kind of advice people can use. Sorry we disagree.
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A56436)
Bulk Lot of NEW...
Toro Sand Pro (A56859)
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A60460)
2020 Ford F-250...
