Did I waste my time? Is operator safer in this case?
   / Did I waste my time? Is operator safer in this case? #41
for me, it's simple.... I alwas turn the tractor off unless I'm just opening/shutting a gate... I've discovered that what I think will take just a second always takes longer... and I don't want to waste diesel. What helps me most is Pat's Easy Change System.... shortens and easyfies (I been listening to the Pres too long:)) hooking up implements.
   / Did I waste my time? Is operator safer in this case? #42
The smart man learns from his mistakes. The wise man learns from the mistakes of others.
Would you rather learn from your mistake, should you make one, or would you rather learn from someone else's mistake? You can take the risk, but all it'll take is once, and you're going to have to take off your shoe to count to ten. . . if you survive.
   / Did I waste my time? Is operator safer in this case? #43
Geez...I thought I'd logged on to the Safety Forum...:D
Never a waste of time...to do the job safely...:)
   / Did I waste my time? Is operator safer in this case? #44
IslandTractor said:
I have zero control over Mother Nature. I can shut off my engine before tempting fate at the PTO end.
AMEN!
2015 Mitsubishi Mirage Sedan (A50324)
2015 Mitsubishi...
Case-IH 165 Puma (A50120)
Case-IH 165 Puma...
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
