did some work with my new tactor today
   / did some work with my new tactor today #1
harry trattner
Hi everyone ,finnally got to do some work with my new (1610d) today ,box scaper and fel work,its all new to me ,tractor works real good ,helping a friend w/ horse c---p ,he has about 5 years spread round beuase he doesn't have a fel on his old 424IH ,so I am useing the box scraper and the loader .All seems to work fine ,but I need to get use to the power shift ,find myself using the clutch alot .As for the locking def.that works great .PS what rpms should I use to do this kind of work? been using 2200,also its a real art to scoop up without going to deep,is there a trick ?My temp light came on and off depending on the slant of the tractor but my gauge read less than half ,so I put water in the overflow (it was down to bottom mark and after that everthing was fine for 3 hours of box and fel work (does that seem ok.)thanks to all ,Harry Ca
   / did some work with my new tactor today #2
Harry,
It's just going to take patience and practice with the FEL gouging.
2200 operating RPM's is fine.
The recovery tank sensor is doing it's job....flashing on/off when the bottle is low. This does not indicate the tractor overheating or temperature gauge is faulty.
Happy tractoring!
Mark
   / did some work with my new tactor today #3
Harry,
Good to hear, half the fun is learning to finese it. Gives you an excuse for more seat time. Mark is right about your light, just a sensor doing its job.
Bruce
   / did some work with my new tactor today #4
You will learn pretty quickly when to curl your bucket before you get in too deep. Once you've gotten a few good loads your instinct will kick in. Same with the powershift. I kept clutching at first, too. It kind of goes against instinct to shift without clutching. My loader seems to work faster and better if I come into the pile with a little bit of a slant on the bucket (teeth down but back of bucket up a couple of inches). I also work the loader with my right hand and the powershift with my left so I don't have to stop or try to go back and forth between the loader control and the shifter. You will enjoy your tractor. Now, I just hope the next time I drive a gear tractor I don't try to shift without clutching. Probably not since my car is a manual and I manage to drive that nearly everyday without incident. Happy tractoring!
   / did some work with my new tactor today #5
That is not the temperature sensor, that is the low coolant sensor.
When you get more seat time on your tractor you will get a feel for the bucket being level and the angle of the bucket. It just takes practice. You may want to try to rig yourself up a bucket level indicator.
How do I do level marker?
   / did some work with my new tactor today #7
Look through the Build It Yourself section here on TBN and search for "bucket level indicator". I know there are a few on here that have built their own.
Case IH Farmall 75C (A52349)
Case IH Farmall...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
Cushman Turf-Truckster Cart (RUNS) (A50774)
Cushman...
Safety Basket (A50121)
