Diesel additive
   / Diesel additive #11
I have an even easier way: I poke a hole about the size of a 16d nail in the foil and squirt some in the 5 gal can or right in the tank. I figure I can guess pretty good about a "double shot" or a little less. If in doubt, squirt again. If I'm really off and I only get 1 oz/5gal, that's better than nothing. If I'm really off and I get 3 oz, it won't hurt a thing.
   / Diesel additive #12
I do the truck and the tractor with my calibrated,scientific,certified,gauranteed,exact,foolproof ...........
splash:cool:
   / Diesel additive #13
I have a "Ratio Rite" cup for mixing 2-stroke dirtbike/atv fuel. It has graduations on it for various ratios, broken down for various volumes of gas. So, 50:1 mix in 5 gallons takes a pint, while 50:1 mix in 2.5 gallons takes 1/2 pint(the numbers are wrong, but you get the idea). They cost about $5 and are great for mixing things in the garage(with plenty of ventilation :D
   / Diesel additive #14
splash:cool:
I use the "glug glug" method. A couple of glugs is equal to one slosh.
   / Diesel additive #15
I use one of those measuring cup things that often come with stuff like Roundup. Two tablespoonfuls (15 cc each) = 1 ounce (30 cc). Just dole them out into the diesel container and move it around a bit and maybe let sit for a spell before using.
If you really want accuracy, go to teaspoonfuls (5 cc each), 6/ounce.
You really don't need to be that accurate though.
Ralph
   / Diesel additive #16
I add stabil to all my fuel as well -- so I took an empty bottle of stabil, filled it half with new stabil and half power service - then use the measure on it to add both at the same time. I marked the diesel stabil bottle very well so I don't confuse the stabil + ps bottle vs. the plain stabil bottle that I use for gas.
   / Diesel additive #17
I use power service and have noticed that since diesel is going low sulfur that the power service has increased in price. Now when I was just in TSC to pickup another container of power service I see these new stickers on the container for the low sulfur diesel and it is now around $14.00
Before all this talk of low sulfur I use to get it all the time for around $9.00
   / Diesel additive #19
Hard said:
I used to be very careful when I measued out the Power Service to add to my diesel fuel. Now I just dump one slosh of Power Service to 5 gallons of diesel. A slosh = 2 ounces. The Power Service bottles have a scale on side to help measure the size of slosh.
Yup, I just 'guestimate".....
   / Diesel additive #20
Hot Tip: Put the additive in the 5 gal container before you get it filled.
Filling the container stirs the contents much better than any amount of sloshing the container around can ever do.
200387 (A51247)
200387 (A51247)
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
BUSH HOG 2820 LOT NUMBER 125 (A53084)
BUSH HOG 2820 LOT...
2019 International DuraStar 4300 24FT Box Truck (A53422)
2019 International...
2006 FORD F-450 XLT SUPER DUTY SERVICE TRUCK (A51247)
2006 FORD F-450...
