Oil & Fuel Diesel Fuel Additives
   / Diesel Fuel Additives #1
RhallVA
VA
Do you folks use any additive to your tracotr fuel or do you use straight #2 diesel fuel (like for a car)?
The last tractor I used on any regular basis needed an additive to replace the sulphur that was taken out of car diesel fuel. Is this not necessary for newer Kubotas?
Thanks!
   / Diesel Fuel Additives #2
I use Power Service fuel conditioner but mostly to prevent gelling in the winter.
No clue about sulfer /w3tcompact/icons/smile.gif
   / Diesel Fuel Additives #3
during the summer months..I use no additive at all..but in the winter months here in New Hampshire..around about October..I will cut my diesel by adding kerosene to the fuel..keeps it from jelling..once I am sure the fuel stations have cut their supply..I no longer add kerosene to my fuel..kerosene will not hurt the motor on my B7500..in fact..it can run on straight kerosene
So I can use the same deisel fuel form the gas station that a deisel car would use?
Thanks!
   / Diesel Fuel Additives #5
I run my F2400 on diesel fuel right out of the pump at the corner store all year around and have never had a problem.
   / Diesel Fuel Additives #6
Yes the same deisel you would put in a car is what you can put in your tractor. I would suggest you use the "off road" deisel it is about 10 cents cheaper. You should be able to find plenty of stations that sell it.
   / Diesel Fuel Additives #7
Last year our diesel fuel was jelling during an extended freeze in our diesel truck. Stanadyne did the trick. I've carried over using it in the summer months. I get better mileage in our truck over summer and winter, no fuel jelling, and we seem to get better overall performance.
Look through this page and those associated with it at:
http://www.dieselpage.com/addtest.htm
Try checking your oil with e free test kit from:
http://blackstone-labs.com/index.html
   / Diesel Fuel Additives #8
Likewise, I've used Stanadyne in my diesels and been extremely happy with it. No jelling at all...and we have some wicked winters. My only complaint about the stuff is I've been unable to find a source except for the annual farm and yard show in Barre, VT. So I'm stuck buying it by the case once a year. /w3tcompact/icons/blush.gif
Pete
   / Diesel Fuel Additives #9
i don't use any additives in my fuel, don't think u need then unless u have EXTREME weather conditions. this is just MHO
   / Diesel Fuel Additives #10
Can you use something like HEAT gas treatment in my fuel?
Grundfos Centrifugal Pump (A50121)
Grundfos...
Two Post Car Lift (A50121)
Two Post Car Lift...
2020 EZ-GO Elite RXV Electric Golf Cart (A50324)
2020 EZ-GO Elite...
John Deere 3038E (A50120)
John Deere 3038E...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
EZ-GO MPT 1000 Electric Utility Cart (A51694)
EZ-GO MPT 1000...
