Oil & Fuel diesel fuel storage
   / diesel fuel storage #11
There ya go, a 15 gallon plastic drum would be perfect. A lot easier to unload and will hold enough to last you 2 months. Just get yourself a hand pump and you're in business. You can take it full, in the back of your truck. Unload it when you get home, in a dry place and refill it on your way back. You'll never have to unload a heavy barrel.
Billy
   / diesel fuel storage #12
If you store your diesel out there will it stay there?
Egon
   / diesel fuel storage #13
Egon,
That's why I don't store on the site ... I have had to many late night visitors in the pass ... so I keep everything used for this place at a relatives farm ... I am carrying enogh fuel in the transfer tank to handle 3 or so days then I replenish ...
Leo
   / diesel fuel storage #14
Jac5n,
The concern I have with a plastic drum stored inside a building is a fire. If a fire occurs in the area, and the heat melts the plastic, you will have a sudden release of fuel that will increase the fire significantly. The dumping of 15-55 gallon of diesel fuel produces a lot of BTU’s of heat real quick. If the drum is in a low cost, do not care if I loose it type of building ( I wonder how many of us have building that falls into this category), then that may be OK. If you use a metal drum inside of a building, make sure it has a UL listed drum vent which will release the pressure built up and release the vapors and pressure without it flashing back into the drum. A tight drum and no way to release the pressure will cause a sudden release of the drum bottom and sides in a great BIG BOOM!
Just another thing to consider with a tractor!
Be safe.
Tom
   / diesel fuel storage #15
I would be concerned that the diesel fuel stored in a large container would get moisture in it storing it outside where you would have drastic temperature changes. Would an additive like Sta-bil, which says its made for gas or diesel, work like PowerService?
arkydog
   / diesel fuel storage #16
I have a 300 gallon overhead tank that I use. I go through 300-450 of diesel a year. I use PowerService in all of my diesel. One gallon of PS does 300 gallon. It has always worked for me in my backup generator no matter the temperate.
Egon,
That's a good question. I'm building a small barn, which should only make the problem temporary. Also, I can lock the gate (I know this is not foolproof). Anyone who wants to hump 55 gallons of fuel on their back is welcome to it!
   / diesel fuel storage #19
I've been storing diesel outside in a 55g blue poly sealed barrel for the last year with no water problems. The poly is flexible enough to collapse a little when the outside temp goes down.
I gravity feed and always collapse the tank a little at the end of the fueling to allow for expansion when the temps go up. No leaks, no spills, no water. I go through the tank about every 2-3weeks so it doesn't sit there for extended periods of time.
I wouldn't consider these barrels as thin walled, they've stood up to some pretty good banging around.
gary
   / diesel fuel storage #20
Great information here. All the opinions are valid. Here is one I use. You can get the correct color for diesel fuel, about 30 gallons. Go to www.cabelas.com
6 Yard Commercial Dumpster (A51691)
6 Yard Commercial...
Grove 4x4 Rough Terrain Hydraulic Crane (A51691)
Grove 4x4 Rough...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
New/Unused CFG Industrial NT18K Mini Excavator (A51573)
New/Unused CFG...
APPROX 500 GALLON FUEL TANK (A51248)
APPROX 500 GALLON...
Killbros 260 Seed Conveyor (A53472)
Killbros 260 Seed...
