Oil & Fuel Diesel fuel vs gasoline
   / Diesel fuel vs gasoline #11
1* Northern Tool has a 25-gallon tank that could cut down the number of trips you make but still get used up fairly quickly. 250 gallons a year averages 50 trips to the gas station a year which is about once a week - not too bad but if you pick up 20-25 gallons once a month or so it may make things easier if you can lug around that much weight.
1*These cost as much or more than building your own better storage rig.
I agree with the simplicity of the 5 gallon can. It's not overly complicated and while yes it is more work than a stand alone tank,
1*it's easy and gets the job done. I use 3 5-gallon yellow diesel cans and just refill them as I need it.
2*I want to look into getting a 30 gallon drum and filling that instead. I feel that that amount isn't an overly large size where you might run into storage problems.
3*Most of the tank sizes on diesel trucks these days are about 30 gallons so I don't see it being a problem.
There are lots of guys on here that have a couple hundred gallon storage tanks and they don't run into fuel complications. As long as you treat any large amount of diesel fuel with fuel stabilizers and bio-cides than the fuel should be good for a while.good.
1*I find 5 gallon cans anything but easy.
2*Something like this?
3*Diesel trucks go through 30 gallon of diesel a lot faster than tractors do.
WH- That's exactly how I do it up North, 5 gallon cans and Power Service white all year.
4*I have a 250 gallon drum of diesel spare (#2) for my home heating that I can tap into if things get rough but basically I use the three can method.
These guys sip oil!
4*I would heat the house and run the tractor all from the same tank.
   / Diesel fuel vs gasoline #12
That's what my son does. When they fill the home furnace oil tank he has them top up the tractor storage tank. For myself, replaced oil furnace with NG in Dec 2006. The little Honda is still running happily on the furnace oil that was pumped out of the old tank. I have a 250 Gal tank with pump, but a full tank would likely last me 10 years.
I use the 20 liter yellow can method for the JD for many reasons:
Fuel use is minimal so inconvenience is not a big factor
Didn't want any possible warranty claim issues from using dyed fuel in JD
Bulk fuel delivery is usually 450 liter minimum
Bulk delivery is / was about $0.10 per liter higher than pump pricing
Pump fuel is always fresh
   / Diesel fuel vs gasoline #13
1*Bulk fuel & red diesel - unless you are running 100s of gal a year - it is not worth messing with.
2*I have a 550 G tank. I have to take atleast 400G or I pay a delivery charge.
3* Also, depending on the supplier - the tax savings can be minimal.
Off road diesel - don't run it in your truck. If they bust you with it - it can be expensive. They will cut your fuel filter open and find the dye - even if you don't have any in the tank at the time.
D.
1*It is for me and i don't run anywhere near that.
2*I can get as little as 25 gallon delevered without any delivery charge.
3*I save about 40 cents a gallon .
Here local fuel dealers 4*require 150g minimum for free delivery, off road dyed red means no tax.
I watch the fuel futures markets and when they bottom in late Jan or early Feb I top off my 240g tank. The dealer recommended a shop for the tank & I added a 12v fuel pump, particulate & water filters. I put it in a shed on a pallet so it's portable.
The tax and market savings averages $1-1.50 gal.
4*like I said I can get 25 gal. and no delivery charge,but the way I set up and operate my set up I aways ger 55 gallon at a time.
   / Diesel fuel vs gasoline #14
1* I find them simple, and they get the job done. For the amount of fuel I use per month I can't justify spending money on a stand lone fuel system yet when it could be better spent else where. Until that time comes I'll keep using my cans.
2* No, not that involved. A 30 gallon drum on a pallet that is the same size square as the drum so that it can be lifted in and out of the back of the truck, with either an electric or manual pump mount to one of the bungs on the drum.
3* Obviously, but 30 gallons of diesel will take me a couple of month's to use in a tractor, where 250 gallons of diesel would take me a couple years. In that couple of months the likeliness of the 30 gallons getting infected is minuscule, compared to the 250 gallons over a number of years.
   / Diesel fuel vs gasoline #15
Uncle Wayne,
I am betting your new tractor will burn less gallons per year than your older gas tractor. I find fuel for my 110tlb and 4520 to be a mnor issue, I would go with the 5 gallon cans first and then decide what you wan't to do.
Steve
   / Diesel fuel vs gasoline #16
2* No, not that involved. A 30 gallon drum on a pallet that is the same size square as the drum so that it can be lifted in and out of the back of the truck, with either an electric or manual pump mounted to one of the bungs on the drum.
1*At 40 cents less per gallon on the fuel and saving the cost of driving after the fuel it don't take long for a rig to pay for itself.
2*This one has the 12 V pump mounted on a shelf but it could have been mounted to the drum bung instead.
If you have a pump / You don't need To lift the drum.
3*Takes me about 2.5 to 3 months to us 30 gallons.
   / Diesel fuel vs gasoline #17
1* That's if you have it delivered, and most places require a certain minimum number of gallons to be purchased for them to even deliver. It's easier to just buy it at the pump, I don't have a fleet to fill.
2* So I've seen, but it's easier to deal with one drum instead of two. Put it in the back of the truck, go to the station, fill it, go home, take it out of the truck, and put in on the floor, done.
3* From May to September I use about 50 gallons of diesel cutting the grass.
Uncle Wayne,
Steve
I called around all my local hardware stores and the big guys such as Walmart, Lowes, Home Depot and the Farmer Co-Ops in the area pricing 5 gallon diesel fuel cans. The price ranged from $11 to $25. I found that the local Grainger had the same can for $6.26 each. If you need a spare or another fuel can, that's a deal. Grainger # 3AA14.
3 Point 5 1/2ft Metal Screen Cargo Carry (A51573)
3 Point 5 1/2ft...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
(30) Galvanized Steel Public Space Fence (A51573)
(30) Galvanized...
2019 UTILITY 53X102 REEFER TRAILER (A52576)
2019 UTILITY...
2012 SULLIVAN PALATEK AIR COMPRESSOR (A52576)
2012 SULLIVAN...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
