Oil & Fuel Diesel fuel?
   / Diesel fuel? #1
Rob52
Bronze Member
Mid Mich
2005 John Deere 4320
Someone I know said they monitor fuel as 2 tanks of #2 and 1 tank of #1? Anyone know the reason?
What should I be using for my new 4320? And why?
Merry Christmas
4320w/400x,hd bucket, LX6, RB1184 w/hydr. /forums/images/graemlins/confused.gif
   / Diesel fuel? #2
Diesel is almost the same as #2 fuel oil. Kerosene is almost the same as #1 fuel oil. For your tractor, you should be using diesel. It'll work on #2 fuel oil.
In the winter, folks in cold states and Canada often mix diesel and kerosene 50/50 to get the solid or pour point down below the normal of around 5 F speced for diesel or #2 fuel oil.
Ralph
   / Diesel fuel? #3
Here #2 diesel & #2 fuel oil are the same thing. I have a 500 gallon tank. It is connected to my furnace & has a pump to fill my tractors.
   / Diesel fuel? #4
No. 2 fuel oil will smell terrible after it is burned. Try to stick to diesel fuel. It also has some additives. Winter (cold wx) diesel is usually a blend of no. 1 and no. 2, as no. 2 will start to gel below 30º or so.
   / Diesel fuel?
Thanks Guys!
Merry Christmas too you!
Rob
Mich
4320w400x,hd bucket,LX6,RB1184w/hydr. /forums/images/graemlins/grin.gif
   / Diesel fuel?
Sorry! Type O!
moniter: as in; observe, keep track of!
   / Diesel fuel? #8
Rob, how are you buying diesel fuel and in what quantities? If you are going to the local gas station or truck stop and filling up a couple 5 gallon jugs, then simply buy regular road grade diesel right from their pumps. As you are in Michigan it will very likely be a blend of fuel at this time of year that contains mixture of #1 and #2 diesel. The reason it is mixed, as previously stated, is to prevent the fuel from gelling in extreme cold. Diesel fuel will begin to gel when it is exposed to frigid temperatures, we worry about it with our truck fleet when the temps stay below 10 degrees for several days in a row. As diesel gets cold it will cloud and gel, the fuel filter can clog with a waxy substance if untreated fuel is used at low temperatures and that will have to be cleaned or the tractor engine will not get fuel. Fuel lines also can easily freeze at very low temperatures (our biggest problem from past experience) as the fuel gels inside the fuel lines.
If you buy your fuel in small quantities, you really don't have too much to worry about as long as temps are 10 degrees or above (my opinion, based on my fuel supply from my supplier). If you buy in bulk, and fill your tank in the spring, summer, or even the early fall (before the end of November) you very likely do not have a blended fuel and gelling issues become a real threat as the temps drop. A simple "anti-gel" treatment, available at auto parts stores and most places that sell diesel fuel is probably all you need. Make sure you buy an "anti-gel" as opposed to a "conditioner" when you shop. Many conditioners claim to have anti-gel properties, but they often have minimal anti-gel abilities so you are better off (this time of the year) getting an anti-gel.
   / Diesel fuel?
That hits the nail on the head! Thanks for the input and info! I kind of figured that out as I only need smaller quantities.
Thanks again.
   / Diesel fuel? #10
Rob, for my home use, I simply keep the tractor tanks full, and keep one or two 5 gallon cans of diesel full. I refill my tractor if the tank drops below 3/4 full to prevent condensation in the tank. By keeping small quantities of fuel around, I never worry about algae growth in the fuel, something that can happen with long term diesel storage. Also by keeping small quantities on hand, I know that my fuel is properly mixed for the season. I will add an anti-gel treatment in very cold weather, and as we have a cold snap that seems to be ending today, I will say I did treat my fuel with anti-gel last week. One bottle will last me then entire winter season.
JOHN DEERE 5125R LOT NUMBER 24 (A53084)
JOHN DEERE 5125R...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
JOHN DEERE 9650 COMBINE (A51247)
JOHN DEERE 9650...
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2015 Ford Taurus AWD Sedan (A51694)
2015 Ford Taurus...
