diesel injector pump leak
/ diesel injector pump leak #1
jroe
mf 35
need infor on how to fix diesel leak around throttle shaft on injector pump on mf 35 diesel.
/ diesel injector pump leak #3
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Parts/Repairs Forum. You'll get a better response there. ;)
/ diesel injector pump leak #4
jroe, welcome to TBN.
No direct experience on MF35, but leaking injector pumps require the attention of a qualified technician. Check the yellow pages or ask around. Most towns of any size usually have at least one diesel shop.
Good luck.:thumbsup:
Jim
/ diesel injector pump leak #5
as already posted leaks at injector pumps require most of the time special tooling and some times a test stand to re-calibrate after working on them if you cannot locate a diesel injector pump rebuilder let me know where your located and i can you in touch with rebuilder in your area.
good luck
Caterpillar TL1055D (A62177)
Caterpillar...
2011 Ford Flex SUV (A61569)
2011 Ford Flex SUV...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A61568)
2014 Ram 1500 4x4...
Kubota Snow plow with subframe
Kubota Snow plow...
2013 Case 850L Dozer (A64047)
2013 Case 850L...
UNUSED RAYTREE RMBD72 - 72" DRUM MULCHER (A62131)
UNUSED RAYTREE...
