Diesel leaking near injectors
   / Diesel leaking near injectors #1
coloradotrout
Eastern KS
JD 4100 HST CUT w/Yanmar 3TNE74 | JD 300 Lawn
My 4100 cut is leaking a bit of diesel near the glow plugs. I tightened one, but still leaking. Any suggestions? Google suggested maybe the lines.
   / Diesel leaking near injectors #2
Check the lines for cracks, could be a crack under the nut on the injector. Clean with brake cleaner, let dry and than look were it gets wet.
Be careful with the high pressure!
   / Diesel leaking near injectors #3
Many injectors have a lightweight return line to permit excess fuel to return to the tank. Check that none have shaken loose. They frequently have plastic fittings which can crack, too.
   / Diesel leaking near injectors #4
Probably the aluminum washer/gasket under the return line..??
Does it have a return line & a large nut holding it down onto the injector.??
IF SO, they have a aluminum gasket/washer under the line.. SOMETIMES u can flip the washer over & reuse it..
BUT my thinking is.. if u took the time to take them all off, replace them ALL..
   / Diesel leaking near injectors #5
I agree with thepumpguysc I usually find one leaks and pend more time and effort in assembly and reassembly over and over
wishing I had just replaces them all (specially when the $ is pretty low on the washers)
2019 FORD F-150XL TRUCK (A51406)
2019 FORD F-150XL...
2015 CATERPILLAR 272D2 SKID STEER (A52709)
2015 CATERPILLAR...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
Niles Pond Engine Lathe (A59213)
Niles Pond Engine...
