Well I pulled the upper radiator hose off right above the thermostat and started the tractor and let it idle for 15 minutes. Thermostst didnt open. So maybe its just cold blooded?? Its 65 degrees outside today. Im gonna still put a gauge in but maybe Im just worrying too much. I did see that while it was running, there was bubbling and diesel leaking around one of the injectors where it goes into the head. Maybe it needs a seal?? Any input would be helpful.
That dose not sound right, the T-stat valve has a notch in it to let any trapped air to escape, you most likely need more 50-50 coolant mix. The normal coolant level is about 1 inch above the radiator core.
BTW, KEEP THE UPPER RADIATOR HOSE CONNECTED AT ALL TIMES. If you want to see what is going on just remove the radiator cap and keep it off before starting the engine. In not, when that T-stat opens you will be eyeball to eyeball with HOT coolant.
The injector hard lines may need a tweak. CAUSION, the fuel pressure at the injector is about 1,400- 2,000 psi and cuts like a razor.
Jinman, x 10.
The advice you have been given is a bit too general.
First you need to know what the temperature spec's are for that engine.
The temperature stamped on the T-stat.
To convert from Centigrade to Fahrenheit, Temp[F] = 1.8 x temp[C] + 32
At 70'C, 1.8 x 70 + 32 = 158'F
At 75'C, 1.8 x 75 + 32 = 167'F
A half hour idling should have the engine warmed to very near the T-stat temperature.
Normal loading should add another 5 deg. or so.
At max power on a hot day you will see 200F.
If you are seeing 210 to 220 F you are at the limits. DO NOT shut the engine down, remove the loan, and let it idle at 1,200 or so rpm to cool down.
YOU MUST ALWAYS RUN WITH A T-STAT.
Temp Gauge, yes. Install the sensor on the engine side of the T-stat.
Pressure Gauge, yes. Install the sensor at the same location as the idiot light sensor with a Tee fitting if you wish to have both.
Break in, yes. Follow the instructions.
Rule of thumb. Oil and filter change after the first 50 hours, then every 100 hr or once a year. Use a CC rated 15w40 oil.
You may also need to torque the head bolts and set the valve lash at 50 to 100 hr. Follow the engine manufactures instructions.
Synthetic oil? Only after 3 to 400 hr of run time.
