diesel vs kerosine
   / diesel vs kerosine #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
OK,
just paid 1.88 for diesel
and saw kerosine for 1.65
just wondering if it can be used in a tractor,
dont want to ruin my machine , just curious, but if it is the same..................
   / diesel vs kerosine #2
I was under the impresion that Kerosine is highly refined diesel, or also jet fuel. Somehow this isn't making sense to me with it being cheaper. I was also under the impresion that jet fuel is good for your diesel as an additive for cleaning out the injectors, but it's not as good as a proper additive since it doesn't lubricate.
I just made myself even more confused trying to figure this one out. /forums/images/graemlins/confused.gif
   / diesel vs kerosine #4
kerosene is fine in the winter used up to 20% it burns hotter and will make winter starts better. But it lacks some lube properties diesel has so ya cant run100% kersene. Where is fuel that cheap? here in Massachusetts I'm paying$2.30 for either diesel or kerosene.
   / diesel vs kerosine #5
Kerosene and jet fuel (essentially same cuts) are the next lighter cuts above diesel and # 2 heating oil (essentially same cuts) off the crude distillation units in refineries. Old timers in Vermont have used 50/50 kerosene/diesel in their diesel cars and tractors in the winter for years. The kerosene keeps the diesel from gelling. Your fuel economy will be a little less with the kerosene because it is a tad lighter in specific gravity. Other than that, you likely won't notice any difference, with as much as 50% mix. I wouldn't use it straight, but it would likely work okay.
For those who want to debate kerosene vs. jet fuel or diesel vs. heating oil. These have slightly different specs from each other but can be the same if the particular crude they get them from matches specs on all. Generally though, refiners have to juggle cuts a little bit on the stills or segregate virgin (direct crude source stuff) and cracked (off crackers that convert heavier-boiling stuff to gasoline) stuff to blend to specs. Some crudes, etc. may require some additional processing to get specs on jet fuel or diesel instead of kerosene and diesel.
Ralph
I live in SC, low taxes keep fuel a little lower,
been too warm to bother mixing anything in the diesel fuel here, another day in the upper60's , low 70's,
weird but wonderful temps, bw
   / diesel vs kerosine #7
</font><font color="blue" class="small">( OK,
dont want to ruin my machine , just curious, but if it is the same.................. )</font>
I bought farm diesel today for $1.54 and they had kerosine for $2.40 a gallon.
maybe I read the nunbers wrong, will look again, bw
   / diesel vs kerosine #9
I just got my 300 gallon tank refilled yesterday.. $1.79.. in March of 2004 it was $1.39.. this is high sulfur off road diesel.
10 FT Poly Bunk Feeder (A55218)
10 FT Poly Bunk...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
2021 JOHN DEERE 624P WHEEL LOADER (A52705)
2021 JOHN DEERE...
2021 GMC SIERRA CREW CAB TRUCK (A51406)
2021 GMC SIERRA...
